firefighter_0029 Posted June 22, 2006 Report Share Posted June 22, 2006 Does anyone know where the Daytime Running Light Module is in a 97-99 Monte? Quote Link to comment Share on other sites More sharing options...
Dirty Rockstar Posted June 22, 2006 Report Share Posted June 22, 2006 Im not sure on the location of the module, but I believe the fuse for it is in a box on the driver's side, in the engine compartment.. Lift the cap, pull the fuse, you're ready to roll.. I think Quote Link to comment Share on other sites More sharing options...
logikf1ve Posted June 22, 2006 Report Share Posted June 22, 2006 I'm assuming you want to keep the Auto-On feature. If you do, the DRL module is located right under the drivers side of the dash, a few inches to the left of the steering column. It's black finned aluminum with a wires and a plug on the bottom. Unplug it and walla, you're done. Otherwise, if you want to disable the DRL's and the Auto-On feature, just pull the fuse out of the fuse block on the passenger side of the dash. It should be labelled "DRL". Quote Link to comment Share on other sites More sharing options...
