Supreme Cutlass Posted June 18, 2006 Report Posted June 18, 2006 Some of the carpet on the doors is starting to come off, what's good to use to glue it back down? Quote
19Cutlass94 Posted June 18, 2006 Report Posted June 18, 2006 Upholstery glue would be best. I would imagine any place that sells rugs/carpets would have it. Quote
1990lumina Posted June 19, 2006 Report Posted June 19, 2006 Double sided tape is what I used lol Quote
THe_DeTAiL3R Posted June 19, 2006 Report Posted June 19, 2006 I'd try contact cement (not the spraycan crap). Try to clean up the area best you can first though. Quote
mfewtrail Posted June 19, 2006 Report Posted June 19, 2006 Buy a can of aerosol carpet adhesive from a local auto parts chain or either a hobby/crafts store. I reglued the carpeted door panels on my Volvo a while back. The carpet was pulling up 1-2'' from the edges of the doors, so I pulled it up a few inches past that and reapplied some glue(after masking off around the door to avoid spraying glue on everything). Quote
GnatGoSplat Posted June 19, 2006 Report Posted June 19, 2006 I used Permatex clear RTV. Works the best in my experience. Quote
DiscoStudd Posted June 19, 2006 Report Posted June 19, 2006 Try 3M spray adhesive. When you use the spray adhesive, be sure you keep the 2 pieces separated for a couple of minutes before joining them (2 minutes after spraying glue on both pieces, that is .) Quote
slick Posted June 19, 2006 Report Posted June 19, 2006 Gorilla Glue? That would take to long to set-up. Quote
THe_DeTAiL3R Posted June 19, 2006 Report Posted June 19, 2006 Try 3M spray adhesive. When you use the spray adhesive, be sure you keep the 2 pieces separated for a couple of minutes before joining them (2 minutes after spraying glue on both pieces, that is .) Yeah nothing beats 3M... Quote
