Z34-5speed Posted June 17, 2006 Report Posted June 17, 2006 Well tonight(6-16-06) i took my 92 Lumina Z34 5 speed back to the track. The only thing that i changed was ; i tinkered around with the intake, got it farther away from the manifold and made a partial heat shield. I also removed the rain guard on the left front to let some heat escape. The temp tongiht was about the same as when i went last time. Tonight my best run, happened to be my first- i let it sit for an hour with ice on the exposed intake pipe, the run was a 16.462 @ 83.83mph. That was my highest trap speed tonight. It was also my second best 60* of the night, 2.478 . I dont think the problem now is my ability to launch, i thought i was launching quite well tonight. After the 16.4 run i consistantly ran a 16.6. I ran 5 of these 16.6s and a 16.5. I had a full tank of gas but i also did last time, and i removed all my speakers and junk in the car. Last time, my best time was a 16.7@83. The car is still throwing an EGR code and a clutch switch code. I will be starting my new job Monday, the $$$ i make will go for replacing the clutch switch and buying Ben's chip and have him turn the EGR off with it. If i have money left over i might take the car to the local Chevy dealer and have them check the injectors and compression. I did take down a few cars though. my friends 2000 Accord V6 3 times and a Nissan passport 2 times. I didn't put this is race stories b/c i was wondering if yall have any more ideas on what could be causing the problems. I wish some of the LQ1 experts lived near here. I tried to scan the timeslip but it wasnt legible so i will post the time: R/T- .356 60*- 2.478 330- 6.898 1/8- 10.622 1/8 MPH- 66.58 1/4- 16.462 1/4MPH- 83.83 Thanks a lot. Kyle Quote
Supreme Cutlass Posted June 17, 2006 Report Posted June 17, 2006 That intake really doesn't look efficient, try putting on the stock one to make sure you're not losing power with that warm air. Quote
Z34-5speed Posted June 17, 2006 Author Report Posted June 17, 2006 I dont have a picture of the revised intake, it's much better than the one in the pics. the 60* times were the best i was going to get out of the car. The best time was achieved with a little bit of tire spin after launching around 3k. I tried launching from all differant places from idle to 5k. I was actually going to put the stock box back on today but i couldn't get the sensor out of the intake pipe so i gave up, not wanting to break the sensor. The tire pressure was at 25 psi on newer goodyear eagles. Kyle Quote
mfewtrail Posted June 17, 2006 Report Posted June 17, 2006 Ouch. What track do you run at Kyle? What was the temperature & humidity during your runs? Since you're in AL, I'm assuming they were both pretty shitty unless you ran late at night(humidity was probably still high then though, it's always like this next door in Georgia at least). Definitely get that stock airbox in there, I don't think it's making your trap speeds that low, but you might pick up a bit with it back in. Quote
Z34-5speed Posted June 17, 2006 Author Report Posted June 17, 2006 The temp was around 70, and it was humid as hell. With my auto i gained 7tenths with 40* weather. Kyle Quote
digitaloutsider Posted June 17, 2006 Report Posted June 17, 2006 Those times are absolutely terrible.. I ran a 14.8 in my Cutlass with an absolutely terrible intake, so I highly doubt that has much to do with it. My trunk was also full of junk, including my tool box. (And I did this at a track not more than 100-something miles from your house) I can't imagine what's making your car so slow.. Quote
Z34-5speed Posted June 17, 2006 Author Report Posted June 17, 2006 I have no idea. The car has 125k miles on it, and seems to have been well taken care of. Maybe the timing is screwed up? The car drives fine around town. Kyle Quote
digitaloutsider Posted June 17, 2006 Report Posted June 17, 2006 The Cutlass is modded, but I don't think it's NEAR enough to make that big of a difference. I've got the 96+ manifolds, no EGR, no cat, FFP chip, and really.. that's it. You should definitely be in low 15's. Quote
Supreme Cutlass Posted June 17, 2006 Report Posted June 17, 2006 You've done a FULL tune-up (fuel/air filters, plugs, wires, injector cleaner) haven't you? Are you running anything like MSD coils or something other than stock? Quote
Z34-5speed Posted June 17, 2006 Author Report Posted June 17, 2006 I did a full tune up when i got the car 3 months ago. New plugs, wires, fuel filter. I run injector cleaner every two tanks or so, here recently at least. The motor is stock(as far as i know). AC delco wires. FFP motor mount. Kyle Quote
per0781 Posted June 17, 2006 Report Posted June 17, 2006 perhaps putting the car on a diet? that r/t needs to be worked on as well. Quote
99RegalGS Posted June 18, 2006 Report Posted June 18, 2006 The Cutlass is modded, but I don't think it's NEAR enough to make that big of a difference. I've got the 96+ manifolds, no EGR, no cat, FFP chip, and really.. that's it. You should definitely be in low 15's. POLY SHIFT BUSHINGS!!!! Quote
Z34-5speed Posted June 18, 2006 Author Report Posted June 18, 2006 I put the stock intake back on today, i will take it back to the track friday to see if it makes any differance. Kyle Quote
sl3196 Posted June 18, 2006 Report Posted June 18, 2006 perhaps putting the car on a diet? that r/t needs to be worked on as well. R/T has nothing to do with 1/4 mile times. Quote
Z34-5speed Posted June 18, 2006 Author Report Posted June 18, 2006 I was about to say that. I can get a .150 r/t regurlarly but i was working on launching. Kyle Quote
