Shifting Theory
I really don't know a lot about transmissons but as i posted ealier mine won't shift above 3/4 throttle, the rpms will raise above redline and still no shift. I was wondering if i overfilled the tranny fluid say a quart or two if it would give the governer enough pressure to shift. Or should i loosen the tv cable? Any Suggestions? Thanks,
In what gear(s)? I've got a trouble shooter list if you can identify when the problem occurs.
- RedFox340
Over filling it shouldnt make it do that. These trannies will work fine if overfilled. Your shifting is based on engine vacuum, so the fluid being overfull is not going to make a huge difference
Robby
Yes loosen the cable up. I experienced that on one of my cars before. The TV cable is probably a little too tight. :) :) :)
I will have to try loosening it up if i can then, I think i found the cable yesterday, it is connected at the throttle and goes back behind the engine, do you adjust it at the throttle or behind the engine, it almost looks like I'd have to pull the engine foward to get at it after the throttel (which the cable ends at and has nothing extra) so i'm not sure how and where to adjust it at. Just to clarify, I have the tranny fluid at the correct level, i was wondering ealier if overfilling it would help, and problem occurs for sure between 1-2, and 2-3, thanks,
On these GM's i'm not sure how you adjust them. You can also try checking your modulator valve in front of the trans to see if its bad. :) :) :)
yeah that modulator is what controls shifting and shift firmness. If the vacuum line running to the modulator is broken or where it goes into the modulator is leaking, you will experience shifting problems.
Robby
I thought it only controlled shift firmness. I guess once i find it i'll check it out, but i have found no vacuum leaks as of now.
