AWeb80 Posted June 10, 2006 Report Posted June 10, 2006 Its a long story, but i'm contemplating sellin the 077's if these xlaces turn out how I want them to....but that said: I'll need new tires for the xlaces as the ones that were on them are kinda old .....6yrs old and kinda crackily....They still have some tread....but i want a 245 tire for the xlaces... What sidewall do i want to be as close to stock diameter that way my speedo will be close to accurate.... I am thinkin somewhere around a 2445/40...to a 245/45....to a 245/50...but don't know which size is the correct one Is there a website that you can punch numbers in and it will tell you mph info and how far it will be off and such? Quote
THe_DeTAiL3R Posted June 10, 2006 Report Posted June 10, 2006 According to this you need 245/55/16 and it will be 0.1% off... http://www.miata.net/garage/tirecalc.html Quote
AWeb80 Posted June 10, 2006 Author Report Posted June 10, 2006 stupid mozilla doesn't have the java plugin......stupid crap. and of course IE freezes if i use it..... Quote
Pontiac6KSTEAWD Posted June 11, 2006 Report Posted June 11, 2006 Try this one. Its supposed to be one without the JAVA plug in.. http://www.miata.net/garage/tirecalcold.html Quote
PCGUY112887 Posted June 11, 2006 Report Posted June 11, 2006 Nooo you can't sell your 077's! Your car looks so good with them! At least keep em and if you like the new crosslaces look you can swap between whenever you feel like it. Quote
GnatGoSplat Posted June 12, 2006 Report Posted June 12, 2006 245/50R16 is what TGP's used. That's what I would get. 245/55R16 may fill more of the wheel well, but they also will come VERY close to the cladding and I think 245/50's fill it more than adequately. Quote
pwmin Posted June 15, 2006 Report Posted June 15, 2006 iirc i ran the stock tires (225/60/16) without problem for a little while. i think the 245/45/16's i have on my xlaces are perfect but were way off, but thanks to my powrtuner, problem solved. you can also go here: http://www.discounttiredirect.com/direct/brochure/info/tmpInfoTireMath.jsp whatcha doin to the xlaces? i just stripped and repainted mine. ill have to post the pics. Quote
