dalejw3 Posted June 9, 2006 Report Posted June 9, 2006 :evil: My volts light is coming on and the battery is running dead, heres the thread i started about it over at Mymonte.com, i thought maybe you guys could help where they haven't.... details here.... http://mymonte.com/discussion/viewtopic.php?t=14813 Quote
Supreme Cutlass Posted June 10, 2006 Report Posted June 10, 2006 :evil: My volts light is coming on and the battery is running dead, heres the thread i started about it over at Mymonte.com, i thought maybe you guys could help where they haven't.... details here.... http://mymonte.com/discussion/viewtopic.php?t=14813 Alternator! Also, many will tell you that the Aux. bold will often come loose, just tighten it down well each time. Get a voltage guage so you can see what's going on, instad of just going off the voltage light. I used to have a problem where there was a short in my electrical system that drained the battery and strained the alternator. Quote
Crazy K Posted June 10, 2006 Report Posted June 10, 2006 if you have a thin brass nut on your auxilary post, repalce it with a REAL nut. the thin ones strip out. sometime in 95 they started using real nuts. Quote
Supreme Cutlass Posted June 10, 2006 Report Posted June 10, 2006 if you have a thin brass nut on your auxilary post, repalce it with a REAL nut. the thin ones strip out. sometime in 95 they started using real nuts. I gotcha real nuts right here Quote
dalejw3 Posted June 10, 2006 Author Report Posted June 10, 2006 I got it figured out, check the mymonte thread for details... Quote
Supreme Cutlass Posted June 11, 2006 Report Posted June 11, 2006 I got it figured out, check the mymonte thread for details... For those of you who are too lazy to go to another forum and want cliff-notes, it was the Alternator Quote
