Guest Posted June 2, 2006 Report Posted June 2, 2006 Does anyone know of an A/C reseal kit? I want to replace all the o-rings (and the accumulator & orifice tube... but I have that covered) while everything's out. Also, I'm kind of worried about debris build up since I didn't exactly cover the ends of any pipes or the compressor or anything when I took them out of the car.. any tips on cleaning things out to make sure nothing will cause damage/blockage when it goes back together? I'll have it vacuumed anyway when it's back together but that will only help with drying the air and getting some of the old oil out. Quote
LukeZ34 Posted June 2, 2006 Report Posted June 2, 2006 This site is your best friend when it comes to AC work.. They also sell flushing agents to clean out the lines.. just to be safe. http://www.ackits.com/ GM O-Ring kit w/ case - http://www.ackits.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=AMA&Product_Code=21-24657B Basic 89-2004 GM O-ring Kit - http://www.ackits.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=AMA&Product_Code=CP3010 Quote
ron350 Posted June 2, 2006 Report Posted June 2, 2006 Post over at that forum and tell them what you are doing and they should help. http://www.autoacforum.com/ These guys are sticklers about flushing the condenser and evaporator. If you are converting to 134a make sure to ask what compressor oil to use. Quote
Guest Posted June 6, 2006 Report Posted June 6, 2006 thank you much guys, exactly what I'm looking for. Quote
