losman7 Posted May 31, 2006 Report Posted May 31, 2006 I have an 04 Impala with the stock amp, i was wondering if i could change the stock speakers and use aftermarket speakers with the stock headunit and amp. Quote
brianhasadd Posted May 31, 2006 Report Posted May 31, 2006 I think you can. I was thinking about doing the same thing and a local audio shop said that I wouldn't be pushing enough power out of the stock amp to power the aftermarket speakers like they should be. I have the Monsoon system in my GP Quote
19Cutlass94 Posted May 31, 2006 Report Posted May 31, 2006 You indeed can. Although chances are you will not meet the 'recommened power handling' of the aftermarket speakers. Quote
DiscoStudd Posted June 1, 2006 Report Posted June 1, 2006 You should be fine as long as you stick with coaxials. I wouldn't try running components off of the stock amp . You can also hook up an aftermarket HU to the stock amp and it will still work fine. Quote
THe_DeTAiL3R Posted June 1, 2006 Report Posted June 1, 2006 Components or bust! I wouldn't even bother replacing your factory speaker with co-ax, cause the sound difference isn't gonna be that much. I've heard 04 Impala speakers and they don't sound that bad... If you want improvement, get a seperate power amp that has speaker inputs (high level inputs??) and run some components. Quote
brianhasadd Posted June 2, 2006 Report Posted June 2, 2006 Components or bust! I wouldn't even bother replacing your factory speaker with co-ax, cause the sound difference isn't gonna be that much. I've heard 04 Impala speakers and they don't sound that bad... If you want improvement, get a seperate power amp that has speaker inputs (high level inputs??) and run some components. I have to agree. That would be your best bet. Quote
DiscoStudd Posted June 2, 2006 Report Posted June 2, 2006 Components or bust! I wouldn't even bother replacing your factory speaker with co-ax, cause the sound difference isn't gonna be that much. I've heard 04 Impala speakers and they don't sound that bad... If you want improvement, get a seperate power amp that has speaker inputs (high level inputs??) and run some components. 100% agreed. The stock Impy speakers sound great compared to most non-Bose GM speakers. They could use a bit more in the "high-range" area, but a set of coaxials definitely won't solve that issue. High-end or bust, for sure. If you need any help in removing your door panels, visit http://www.impalahq.com . The site has a write-up on how to get at your door speakers ... Quote
chevyguyss18 Posted July 8, 2006 Report Posted July 8, 2006 Thats for sure. My 04 impala stock speakers were great, of course cranking them at the levels i listen to music, i still didnt get the level of clarity i wanted to be at. As far as speakers, If your still running the stock HU and stock amp, its pointless to replace your speakers. Stock amps and stock amps go hand and hand as their made to work together. Replacing the HU and replacing the speakers would help alot , but still not going to get HIGH class sound. This is because the stock amp basically works against you when it comes to tuning the stereo. You can definately get it to sound good, but the best way to go, is replace HU, replace speakers, and either bypass stock amp, or just put in a new amp. which is what i did. sounds good right (97loudcut) Quote
97loudcut Posted July 8, 2006 Report Posted July 8, 2006 sounds decent I would bypass the stock amp and buy a new HU and speakers and let it purrrr. my 6x9's are not hooked up to an amp and they sound great. Quote
Cam'ron Posted July 8, 2006 Report Posted July 8, 2006 as soon as you break anything up in the factory system it will not sound good IMO, replace 1 thing with aftermarket = replace it all my 2 pennies... this is the exact reason i havent touched my montes stereo yet, for factory i am very pleased with its performance, i had $2500 worth of stereo in my buick and yeah i miss the bass but my monte is no slouch as far as factory systems are concerned Quote
19Cutlass94 Posted July 9, 2006 Report Posted July 9, 2006 Well the stock systems that the factory uses have come a LONG way. They actually sound pretty good! Although nothing compared to a good quality aftermarket company. Honestly, I prolly spent about $300 on Infinity speakers for my car, and I dont even use them anymore. I took the front ones out completely because the Componet set sounds soooo good. And the rear I just turned off because no one is ever in the back seat. Im for the Component set as well. If you buy that and a good amp that will power them, you wont need anything else. Maybe rear speakers for rear fill ( which really isnt needed all the time ) and a sub if you prefer to have. Atleast this is the case with me... Quote
