starts then stalls
99 L67. intermittent problem. car starts n runs fine then cuts out 1-2 secs later. it stalls very smoothly, like as if the car was meant to do that. if i bring the rpms up itll bring them right down and cut out. one time it just didnt start at all. crank sensor? anything to do with the resistor in the key maybe?
OT: !!! You haven't been here for a long time!
OnTopic: It might be the resistor pill in the key, does it flash "SECURITY"?
yeah i know. heh sorry if it seems like im just usin the board for my own benefit.
anyways no, no security light. that probabaly means its not the key. no codes stored or active
ideas? cmon where the A techs at? maybe does anyone have access to the GM dealer site so i can read the service manual online and research myself?
more than likely its the crank sensor, but another thing is when was the last time you had a tune up, if you say its intermitted. could be as easy as a clogged fuel pump.
http://jbarbieri.net:9001/
