Psych0matt Posted May 31, 2006 Report Posted May 31, 2006 So, I did a little bit of searching and found that 6* 6* is the best setup for some power gains. question is: can anybody give me a simple answer as to how many teeth things need to be altered? if I can just cound teeth and not have to use some wheel with lots of numbers, that would make it a lot simpler for me. I was going to try and retime it this morning, but my roommate who has the small screwdriver (to reset the actuator) works til 12, and i have to head to detroit around 2 or 3, so I'll probably drive it to work and back timed crappy tomorrow, and retime it after work tomorrow. maybe hopefully now I can do this timing mod if it can be done easily enough. Quote
patgizz Posted May 31, 2006 Report Posted May 31, 2006 count teeth on the cam gear and divide by 360. Quote
Psych0matt Posted May 31, 2006 Author Report Posted May 31, 2006 *smacks self in the forehead (anyone know how many teeth are on the 94 cam gears? [/sheepish question]) I'll probably just time it normal so i can get it right, unless im 100% sure i can do this anyways Quote
