ns87 Posted May 28, 2006 Report Posted May 28, 2006 In April I had both rear struts replaced. The were shot, and one collapsed when they took it out They used to make a groan/creek noise. I have meanwhile taken 4 150+ road trips, and no noise until today. Suddenly that noise is back, except with my new struts. Whats the dealio~? Impression of the noise is creeEEEeeeaaak-a-a-a-a--a-a-eeeeeek ::silence:: repeat. Say that outloud and thats what it sounds like If its my monoleaf, hello Birchmount Quote
94CutlassSLCoupe Posted May 28, 2006 Report Posted May 28, 2006 your monoleaf pads are either shit OR your rear window is creaking like it does in my car Quote
per0781 Posted June 5, 2006 Report Posted June 5, 2006 mine creeks too. oh well. i turn up the radio. Quote
Pabz Posted June 5, 2006 Report Posted June 5, 2006 Monoleaf pads man, it used to sound exactly like you mentioned. Oh and if you dont like the sound, i would stay away from birchmount. Quote
ns87 Posted June 5, 2006 Author Report Posted June 5, 2006 per0781: Yours only creaks bc its a clone of mine Pabz? Whats the non squeeky brand then? Quote
Pabz Posted June 6, 2006 Report Posted June 6, 2006 per0781: Yours only creaks bc its a clone of mine Pabz? Whats the non squeeky brand then? I am using these pads that i made from a stip of rubber that has a cloth mesh sandwiched inside. i am using 3 of these on each side which puts approx 1/2" - 3/4" of material between the spring and the knuckle. Running on over a year and no noise. The creaking comes from the rubbing the leaf spring does where it contacts the knuckle. The reason why mine dont creak is probably because the rubber pads i use stay stationary while the leaf moves on top of them. I would rather the rubber be attached to the knuckle rather then the end of the leaf spring. Quote
Pabz Posted June 7, 2006 Report Posted June 7, 2006 who needs pads? I had mine down to less than 1/8" So i installed a birchmount. I wanna see pics of one wearing down on the trailing arms, that would be crazy (possible?) Quote
per0781 Posted June 7, 2006 Report Posted June 7, 2006 I wanna see pics of one wearing down on the trailing arms, that would be crazy (possible?) give me time Quote
Q-Ball Posted June 9, 2006 Report Posted June 9, 2006 Check your pads. I have a problem with mine. When the rotor spins, it causes the pad to move and make a slight clinking sound. To fix my prob is either get a new rotor, or get this glue/sealent and put it behind the pad to keep it in place. Quote
ns87 Posted June 9, 2006 Author Report Posted June 9, 2006 This damn car. So tired of putting money into it lol, Everytime I fix something on the outside, my dash warps more or something else breaks on the interior Quote
1990lumina Posted June 9, 2006 Report Posted June 9, 2006 I saw a GP on the freeway yesterday with two broken trailing arms and the monoleaf snapped.....whole ass was an inch away from dragging on the pavement.....poor car. I just bought some new struts, and I'll be buying those new pads for my monoleaf...hopefully that eliminates the clunks and knocking I'm having, and get my ass end level again....hell if it is jacked up higher the nthe front even I'd be happy. I'll keep you posted if new pads help my car Quote
AWeb80 Posted June 10, 2006 Report Posted June 10, 2006 your rear window is creaking like it does in my car Mine used to untill I put the RSTB on. Quote
