one_fast_prix Posted May 27, 2006 Report Posted May 27, 2006 saw this and was wondering what are stock alternator's specs are at, i know they're like 100 amps, but what are they cranking out at idle and hot and cold. this one says 70-80 at idle. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7933450141&fromMakeTrack=true Quote
Puggsley456 Posted May 27, 2006 Report Posted May 27, 2006 saw this and was wondering what are stock alternator's specs are at, i know they're like 100 amps, but what are they cranking out at idle and hot and cold. this one says 70-80 at idle. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7933450141&fromMakeTrack=true Honestly....a high output alternator isnt even needed unles you a running a ton of power. I was having alternator issues, so I upgrade my battery, BIG 3 and alternator all at the same time. Everything was fine. Then my high output alternator went, so I put in a lifetime warranty bosch alternator and there has been no noticeable difference since I change back. Quote
one_fast_prix Posted May 28, 2006 Author Report Posted May 28, 2006 what is the big 3 again, i have a cap and soon getting a yellow top for the truck and leaving my reg. wal-mart special in the front. Quote
19Cutlass94 Posted May 28, 2006 Report Posted May 28, 2006 'Big 3' is basically alt to positive battery terminal, positive battery terminal to AUX post, negative battery terminal to ground ( then you can have another from that same ground to the engine block for a better ground ) On a side note, Im surprised almost everyone that has a W that has a system in it has a cap or bettery battery, more than one battery etc etc. I only have a 'Big 3' thats it. back to scheduled program Quote
Puggsley456 Posted May 28, 2006 Report Posted May 28, 2006 This will give you a good explination of the "BIG 3" and how to do it. http://forum.sounddomain.com/ubb/ultimatebb.php?ubb=get_topic;f=5;t=007801 Quote
Psych0matt Posted May 28, 2006 Report Posted May 28, 2006 for those of you who did it, how did you actually go about doing it? (larger wires, cleaning up/making new contacts, etc?) Quote
19Cutlass94 Posted May 28, 2006 Report Posted May 28, 2006 You add wire to whats already there, do not replace. I used 4g wire for mine, but if you have a bigger demand for current, you can use 1/0g wire. Quote
Puggsley456 Posted June 7, 2006 Report Posted June 7, 2006 I just found out that knukonceptz.com is selling high output alternators.. for most Gm and Fords.....If they are a good as their wires lookout.. http://www.knukonceptz.com/productMaster.cfm?Category=Alternators Quote
19Cutlass94 Posted June 7, 2006 Report Posted June 7, 2006 Is this just recently they started selling for GM? I remember looking at em a while back and didnt see any. Quote
2CUTTYS Posted June 7, 2006 Report Posted June 7, 2006 Stupid question MB if you have your old one done, does it need a new casing? Quote
