TheEddie Posted May 27, 2006 Report Share Posted May 27, 2006 Car:1999 Monte LS 3100 Alright, so earlier today I tried remote starting my car and I always listen for it...nothing. I go outside and hit the button again...car clicks(more like a ping) and does nothing. I get in the car and it started right up. About 3-4 starts later im in the Jewel parking lot and I try to start it again, click...nothing. Try it again, click. What do you guys think it is? I've been reading up on started problems all over this place and I figure it is the starter. I tried beating the piss out of it while someone turned the key but no luck. The battery is good-I even jumped it while hitting the starter and trying to start and nothing. Just the one click. If it is the starter what do you guys recommend, I've read about the misc. starters that can be used including the gear reduction starters. Educate me on the topic please. Quote Link to comment Share on other sites More sharing options...
LumiDriver Posted May 27, 2006 Report Share Posted May 27, 2006 My thoughts would be the ignition module...or just teh way GM starters are. Did that too me as well. Check your connections too. I had a loose battery ground when my van did the same thing. Quote Link to comment Share on other sites More sharing options...
TheEddie Posted May 27, 2006 Author Report Share Posted May 27, 2006 I had the ICM and Coil Packs checked probably 100 miles ago, everything was a-ok. I wish it'd start just once so I could get it home, ha. Quote Link to comment Share on other sites More sharing options...
joey b Posted May 27, 2006 Report Share Posted May 27, 2006 turn the key to the on position and leave it until the dummy lights turn off and see if the security light is illuminated. Sometimes when I go to start my car I have to hold it in the start position for sometimes 5 seconds before the starter will engage. Don't know why. Quote Link to comment Share on other sites More sharing options...
94CutlassXtreme Posted May 27, 2006 Report Share Posted May 27, 2006 My car does this all the time. Check the power distribuiton module under the hood where the alternate positive post is. There should be a little red wire bolted to the side of it. Wiggle it and then try and start the car. If it works, the car should fire right up and then tighten it down asap. I think its the power for the starter relay or something. Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted May 27, 2006 Report Share Posted May 27, 2006 my remote start almost never works (unless I accidentally hit it while working on it or something) but always starts up with the key. no idea why. my aux post was loose for a few days, but i cleaned up the connections real good and tightened it yesterday. ill try my remote start on my way out to work today. newer 3x00 starters work just fine you just sak for a starter for say a 2001 malibu with a 3100 or a 2001 impalla with a 3400 That's what I did. works fine Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted May 27, 2006 Report Share Posted May 27, 2006 Try seeing if it starts in Neutral. It could be your park/neutral safety switch that's out of whack... Quote Link to comment Share on other sites More sharing options...
skiiirt Posted May 27, 2006 Report Share Posted May 27, 2006 Try seeing if it starts in Neutral. It could be your park/neutral safety switch that's out of whack... Quote Link to comment Share on other sites More sharing options...
TheEddie Posted May 28, 2006 Author Report Share Posted May 28, 2006 I tried all of that^^ before I even posted...read up like mad looking for answers..no luck on anything so I skipped a few steps, towed the beast home with my moms expedition and got myself a new starter-lifetime warranty. Put it on in less than an hour with no experience at all. She runs like a champ. I own. Thanks for the help guys, it's always appreciated. Edit:Finished the job 7 hours before I had work. Quote Link to comment Share on other sites More sharing options...
