disconnect the ABS on my car? its acting up again and i belive the simplest solution would be disconecting it. is tere anything i should be worried about after disconnecting it. id appreciate it if someone would show me where and how to disconnect it (pictures maybe?)
Pull the fuse....
In my 1994 GP owner's manual it's on page 234, says it's fuse #33 (5amp) I have no idea if it's the same on your car or not. This will stop if from working, I dunno if the ABS light will come on permanently though...
Basically, you don't want the ABS to be on right? If that's the case, just pull the fuse. But, be weary, if you do this, your ABS dummy light will kick on. You could always pull that bulb out of the cluster though.
