kuntzie Posted May 23, 2006 Report Posted May 23, 2006 the gt2871r... bigger then the disco potato Quote
z284pwr Posted May 23, 2006 Report Posted May 23, 2006 :eek: Awesome!!! How much modification if any does it appear will need to be modified to make it work, or is it hopefully a direct bolt it? Quote
GutlessSupreme Posted May 23, 2006 Report Posted May 23, 2006 What's that, like double the inlet size of the T25? miserable little thing Quote
skalor Posted May 24, 2006 Report Posted May 24, 2006 Looks good and I can't wait to see what she'll run with it!! Quote
kuntzie Posted May 24, 2006 Author Report Posted May 24, 2006 :eek: Awesome!!! How much modification if any does it appear will need to be modified to make it work, or is it hopefully a direct bolt it? direct bolt on, needed to get a new coupler for the turbo to intercooler pipe What's that, like double the inlet size of the T25? miserable little thing oh ya shes big Looks good and I can't wait to see what she'll run with it!! took her out forr her first "maiden voyage" going about 2/3 throttle max (about 5-7 psi) this thing Flew... my guess is that juds crown is gunna get taken away nextweekend Quote
z284pwr Posted May 24, 2006 Report Posted May 24, 2006 :eek: Awesome!!! How much modification if any does it appear will need to be modified to make it work, or is it hopefully a direct bolt it? direct bolt on, needed to get a new coupler for the turbo to intercooler pipe What's that, like double the inlet size of the T25? miserable little thing oh ya shes big Looks good and I can't wait to see what she'll run with it!! took her out forr her first "maiden voyage" going about 2/3 throttle max (about 5-7 psi) this thing Flew... my guess is that juds crown is gunna get taken away nextweekend :eek: :willynilly: :drool: :twitch: :Yikes_anim: Words can't explain how sweet that is!! I'm guessing you got that from ATP Turbo? Oh and good luck hooking that beast up now Quote
kuntzie Posted May 24, 2006 Author Report Posted May 24, 2006 its already hooked up... oh ya hooked up at the track... ya there could be problems there, and no not apt turbo on a side note, i could have gotten jud new turbo for 20 bucks less, or the disco potato for ~ 100 less then i paid for thisi talked to numerous perple and this was the turbo to go with in everyones opinion Quote
Guest TurboSedan Posted May 24, 2006 Report Posted May 24, 2006 that's the biggest i'd go without going to better GEN-III heads/intake. did you get the .64 or .86 A/R turbine housing? did your oil and/or coolant lines need to be modified? Quote
mfewtrail Posted May 24, 2006 Report Posted May 24, 2006 Nice, can't wait to see how you'll run with that turbo. BTW, Jud doesn't run that GT28R he used to have anymore...he's had a GT3076R since sometime last year. "The GT3076R-WG packs the 500HP capable, quick spooling 52 trim 76mm compressor found in the popular GT3037 with the high flowing 90 trim turbine wheel found in the bigger GT3071R-WG, making it the highest flowing turbo available in the internal wastegated configuration. Ideal higher power upgrade for GT28RS/GT2871R/GT3071R-WG setups looking for a lot more power." I think Jud has a LOT left in his car soon as he gets everything squared away and running good. Quote
TGPilot Posted May 24, 2006 Report Posted May 24, 2006 my guess is that juds crown is gunna get taken away next weekend :lol: Ummmm junior you have a long way to go before you take Jud down. Jud is no wheres near his max potential. Only thing holding him back at this point is the tranny that is beefed up but will not hold the power he is putting down with slicks. If you do beat his time you need to realize that Jud is not young and dumb like us (at least my mentality )...he is trying to save his tranny. Quote
kuntzie Posted May 24, 2006 Author Report Posted May 24, 2006 ya i know hes got more potential. but hes hasnt gotten it below 13.5, i know he could just turn up the boost and hit 12s, all im saying is i think my car can hit mid to low 13s the way it sits now. we will see though, i could be totally wrong. you gotta rememberjuds got a 3400/3500 hybrid goin on to which would help him alot. i cant wait for this wekend to see the actually #s, the tranny can take the abuse i think no problem but im worried about the clutch now, i know 13s for sure now though untuned the way it is (on street tires too) Quote
GutlessSupreme Posted May 24, 2006 Report Posted May 24, 2006 I hope you don't plan on running it untuned... not while you're pushing that much air. Asking for some catrastrophic trouble there. Quote
Garrett Powered Posted May 24, 2006 Report Posted May 24, 2006 its already hooked up... oh ya hooked up at the track... ya there could be problems there, and no not apt turbo on a side note, i could have gotten jud new turbo for 20 bucks less, or the disco potato for ~ 100 less then i paid for thisi talked to numerous perple and this was the turbo to go with in everyones opinion did you have to drill a hole in the DP for the O2 sensor? Quote
GOT2B GM Posted May 24, 2006 Report Posted May 24, 2006 Have fun, just be careful and don't push it too hard, I don't wanna see you blow the motor on that thing. Quote
kuntzie Posted May 24, 2006 Author Report Posted May 24, 2006 its already hooked up... oh ya hooked up at the track... ya there could be problems there, and no not apt turbo on a side note, i could have gotten jud new turbo for 20 bucks less, or the disco potato for ~ 100 less then i paid for thisi talked to numerous perple and this was the turbo to go with in everyones opinion did you have to drill a hole in the DP for the O2 sensor? yup drilled a hole in the DP for the 02... worked flawlessly. oh and its tuned now (just got a new chip) had an a/f gauge hooked up and didnt go lean at all at 8 psi.. (i now there not very accutare but still, exhaust smelt good too) dont worry i wont try and push it too hard Quote
futuretgper Posted May 24, 2006 Report Posted May 24, 2006 kuntzie did you upgrade injectors!?!? Quote
kuntzie Posted May 24, 2006 Author Report Posted May 24, 2006 yup 29# injectors.... the aslo listed in my signature Quote
kuntzie Posted May 25, 2006 Author Report Posted May 25, 2006 still dont got my camera back from repairs so heres a quick shot from my camera phone Quote
futuretgper Posted May 25, 2006 Report Posted May 25, 2006 ah i see it in ur sig now!! bad ass pic!! good luck and get us some video!! how well did it go in?? any clearance issues?? what are you doing for an air filter? im so incredibly jealous right now!! who tuned the chip for you??!! Quote
kuntzie Posted May 25, 2006 Author Report Posted May 25, 2006 ah i see it in ur sig now!! bad ass pic!! good luck and get us some video!! how well did it go in?? any clearance issues?? what are you doing for an air filter? im so incredibly jealous right now!! who tuned the chip for you??!! thanks man. ya the only problem was the wastgate hitting against the coolant pipe, oblonged the holes a tad (didnt want to adjust the turbo housing as it was perfectly setup) it went in pretty easy, had to buy all new lines running to and from the turbo though. oh my air filter, a heavy duty female figureskating tights (well a piece of one) my road is really dust as they are tearing apart the roads and repaving everywhere in my neighbourhood/ subdivision. im going to make an intake for it or something just gotta figure it out. (no room) dont be jelious skalor tuned the chip, sent me the bin file and my one buddies friends burnt the chip for me. it runs awsome and definitly not lean, no bogging or issues yet. (10 or 15 miles maybe) oh ya the turbo spins so nice its crazy, for like 30 seconds at least after the car is shutoff. im still getting some finetuning done by the people that make the 3800 turbo kits up her in canada (cartuning) after the cam, and P&P (and bigger TB too) Quote
z284pwr Posted May 25, 2006 Report Posted May 25, 2006 Damn, that fits in there quite nice.... I think I may have to sign me up for one of these Now hurry up weekend so we can get some E.T.s!!!!! Quote
intern8tion9l Posted May 25, 2006 Report Posted May 25, 2006 holy crap thats awesome! def want to see some numbers Quote
Garrett Powered Posted May 25, 2006 Report Posted May 25, 2006 you are working with cartuning? thad be nice. They gonna hook you up wit a big TB or you got one in mind? I was thinking about boring out the stock one a little. Quote
kuntzie Posted May 26, 2006 Author Report Posted May 26, 2006 cartuning will be working with me to make this even better then it is yes, thery are going to do the final tuning and dynos for me aswell. this is the TB i am getting..(62mm) Quote
