Can I swap a 3100 for my 2.8L?
I have a 89 Cutlass with a 2.8L. I just had a freshly rebuilt 3100 Vin M out of a 1994 given to me. Is it possible to swap it for my 2.8L Do I just need to use a new prom? With the motor mounts and wiring work? Also I need a upper intake and plenum for this motor if anyone has one for sale.
I dont think the dogbones from your 2.8 will work, and yes you would need a new computer
Robby
yes you can swap it right in, very little modification necessary, and yeap you can use your upper mounts. Also wiring is at a minimum, you can have your current computer control it
I should also add that it'd run better with a 3.1L memcal, but you'll need one from an '89 due to your egr. But when converting to an 89 memcal you'll need to swap out your speed sensor on your tranny with an '89 one otherwise you'll get false readings. This will also remove your MAF sensor if you never got the recall taken care of. As for the upper plenum, get one from a 94-95 because it will have the proper mounting for the EGR. Hope this helps
Didn't 94-95 have a Digital EGR? In that case, his ECM can't control the EGR without running more wires and using a 90-92 MEMCAL.
96+ uses Linear EGR which is pin compatible with Vacuum EGR, although the connectors may be different. The signals Linear EGR requires (PWM Duty Cycle to control EGR opening) is also very similar to Vacuum EGR. I don't know that Linear EGR will actually work in place of the vacuum EGR, but the signals are pretty much the same.
Guest Anonymous
I know my '94 Cutty has the digital EGR.
How can he use a 3.1 chip? Doesn't the 3100 have a cam sensor that the 2.8/3.1 didn't have?
It does, but he doesn't have to use it!
He'd need to use wiring from the original 3.1L. That will make the injectors bank-fired instead of sequential, so the cam sensor will just be unused.
