Intlcutlass Posted May 22, 2006 Report Posted May 22, 2006 As the topic says , Anyone have a part number or a source? Quote
5speedz34 Posted May 22, 2006 Report Posted May 22, 2006 I think they are part of the arm assembly... Quote
Guest TurboSedan Posted May 22, 2006 Report Posted May 22, 2006 i think you can get them through rockauto.com i don't know where you'd get poly though. Quote
5speedz34 Posted May 23, 2006 Report Posted May 23, 2006 i think you can get them through rockauto.com i don't know where you'd get poly though. If you want poly you should get the BMR arms. Quote
lakefxgp96 Posted May 23, 2006 Report Posted May 23, 2006 i think you can get them through rockauto.com i don't know where you'd get poly though. If you want poly you should get the BMR arms. Know of anyone running these? I know the 97+ guys say they are great but are they worth the $400? Quote
5speedz34 Posted May 23, 2006 Report Posted May 23, 2006 i think you can get them through rockauto.com i don't know where you'd get poly though. If you want poly you should get the BMR arms. Know of anyone running these? I know the 97+ guys say they are great but are they worth the $400? No, I don't know of anyone on this board with them. If I ever get the cash my rear suspension will be. Quote
Intlcutlass Posted May 23, 2006 Author Report Posted May 23, 2006 i think you can get them through rockauto.com i don't know where you'd get poly though. If you want poly you should get the BMR arms. I don't want poly..... I want to replace the old rubber. Quote
Guest TurboSedan Posted June 18, 2006 Report Posted June 18, 2006 Lee, did you end up getting new stock rubber bushings? i am sorta in the middle of replacing the rear struts and mine look horrible. i really want to replace them while i have the struts & knuckles removed. i'm a little confused as to how many bushings to order; how many come per package etc. it looks like i could get AC Delco or Moog through rockauto.com. also, are inner bushings (the ones toward the middle of the car) the same as the outers (the ones under the knuckle)? btw, did anyone ever find poly bushings for the lateral arms? Quote
Intlcutlass Posted June 19, 2006 Author Report Posted June 19, 2006 Lee, did you end up getting new stock rubber bushings? i am sorta in the middle of replacing the rear struts and mine look horrible. i really want to replace them while i have the struts & knuckles removed. i'm a little confused as to how many bushings to order; how many come per package etc. it looks like i could get AC Delco or Moog through rockauto.com. also, are inner bushings (the ones toward the middle of the car) the same as the outers (the ones under the knuckle)? btw, did anyone ever find poly bushings for the lateral arms? No I didn't get them... The rear end I got from Patgizz, was in really good condition, and the bushings were fine... Sorry man.. But, Rockauto DID have them.... Quote
