also posted on TGPforums.com: Have my first TGP problem. Car was running fine, then just died. I restarted, idle high, service engine light on, low cooland light on. Gave it some gas, it died. Checked codes, got code 22 and 34. I reset computer (unhooked ground), same codes, would drive, and idled better, but not correctly. low coolant ans service engine light still on. Car is not low on coolant, or overheated. Book says codfe 22 TPS (replaced TPS imediately, no change). Book says code 34 could be bad MAP to ECM connection. Checked, seemed ok. Book says could be bad MAP sensor, replaced MAP sensor, no change. Book also says could be bad ECM. Replaced ECM, ran fine for a day, then acted up again, Seems to get that way after start up. Any input would be appreciated.
Things replaced:
ECM
ICM
MAT
MAP
ICM
Coils
Plugs
Wires
