95 BLKDOUT Drop Top Posted May 15, 2006 Report Posted May 15, 2006 Ok heres the deal, my 3100 is just about dead with close to 170,000 miles on it so I need a new motor. instead of replacing it with a 3100 i wanna do a 3400 or a 3.4 DOHC swap for the power. they shoulda never made the cutlass convertibles with a 3100 because the car is jus too damn heavy. My questions are what would be a better swap for my ride and what all will i need to do to swap it over from a 3100 to a 3.4 or 3400, i kno the 3.4 will jus drop right in with minor mods but im not sure about the 3400 Quote
patgizz Posted May 15, 2006 Report Posted May 15, 2006 jay. with the exception of a few small things, the 3400 is the most direct swap and can use your 3100 ECM and injectors. if you need help hooking things up let me know. Quote
chadz34 Posted May 15, 2006 Report Posted May 15, 2006 you would say that avatar = I'm sure you are with me Matt! And, in addition, my signature also features the LQ1. Quote
Psych0matt Posted May 15, 2006 Report Posted May 15, 2006 your signature features a: "oops! my image for this link is no longer here Hosted at Photobucket" (and yes, I agree DOHC, but 3400 would be easier) Quote
95 BLKDOUT Drop Top Posted May 16, 2006 Author Report Posted May 16, 2006 can i jus drop in a GA GT 3400? what are the pros and cons of the 3400 so i can kno exactly what im dealin wit Quote
Psych0matt Posted May 16, 2006 Report Posted May 16, 2006 can i jus drop in a GA GT 3400? no, different mounts (aside from that, yes) Quote
95 BLKDOUT Drop Top Posted May 16, 2006 Author Report Posted May 16, 2006 so the only dif is probably jus the dog bone right, other than that itll bolt up to my 3.4 DOHC tranny mounted to my current 3100, computer will work and all that good stuff. what about the power differences Quote
Psych0matt Posted May 16, 2006 Report Posted May 16, 2006 i believe the tranny and computer will work (probably eventually want to get the right computer), but i think the lower mounts are what's different, making some custom work. *I think* Quote
patgizz Posted May 16, 2006 Report Posted May 16, 2006 all the swap to a non w-body 3400 needs is the mounts(lower and dogbone bracket) swapped from the 3100 to the 3400. physically otherwise it is the same engine on the outside. aside of the EGR differences over the years and exhaust manifold outlet differences over the car lines. Quote
SigEpCutlass Posted May 16, 2006 Report Posted May 16, 2006 If you put in a 3400, make sure you change the intake gaskets with the new GM ones first!!! Quote
95 BLKDOUT Drop Top Posted May 17, 2006 Author Report Posted May 17, 2006 i guess ill do a 3400 swap then. Pat, be expecting a visit pretty soon, as soon as i get the 3400. well i kno the power increase because last summer i got roasted by a GA GT with a cold air intake and a custom flowmaster exhaust. left me in the dust. Quote
patgizz Posted May 17, 2006 Report Posted May 17, 2006 let me know if you need any help once you tear in, i did the 3400 swap into the lumina last winter. Quote
95 BLKDOUT Drop Top Posted May 18, 2006 Author Report Posted May 18, 2006 is it any better than the dohc? Quote
patgizz Posted May 18, 2006 Report Posted May 18, 2006 not performance wise, but its by far an easier swap, easier to work on(loads of room in the engine bay), and is not as expensive to repair, the alternator isn't in the bottomless pit, and it doesnt have a timing belt to keep up on. plus you'd about need a complete running donor car because of all the little things that are different. Quote
95 BLKDOUT Drop Top Posted May 18, 2006 Author Report Posted May 18, 2006 ok well i guess ill be lookin for a totaled grand am Quote
