colwell Posted April 17, 2003 Report Posted April 17, 2003 How do i take out my backseat of my lumina z34? I wanted to take it out so i can run my speaker wires to my trunk bypassing the bose amp. Quote
NOHC_WBody Posted April 17, 2003 Report Posted April 17, 2003 Look below the front of the lower cushion, where it meets the floorboard. There should be two 10 or 12 mm bolts holding the lover cushion in. Pull it forward/up to get it out. You shouldn't have to, but to get the seatback out, take the two nuts off at the bottom, which were covered by the lower cushion, and pull the seatback straight up to take it off the "hooks" behind it. [edit] are you ditching the BOSE amp? Want to get rid of it? Quote
Redfox340 Posted April 17, 2003 Report Posted April 17, 2003 Towards the front of the car (underneath the seat cushin) there will be two bolts; 13mm in size if I remember right. Unbolt those and pull the lower foam out. Next find the two 11mm nuts for the top part and unbolt those... then push up on the cushin to release and pull out of vehicle. Have pictures if needed; that's what was done to get my back seat of of my Cutlass, should be the same for you. GM uses the same bolt patterns for the same frame... gotta love it! EDIT - NOHC, you're quick... darnit! - RedFox340 Quote
NOHC_WBody Posted April 17, 2003 Report Posted April 17, 2003 Ah, I remember backseat removal well. I took that interior out for Shane, and did it TOO many times on my GTP, seeing as I had to upgrade power wire three times, finally down to "0" guage wire for the RF 1000 and the Atomik DVC 12's Quote
JS91Z34 Posted April 17, 2003 Report Posted April 17, 2003 Damn when I gutted my Z34, evry damn bolt was a 15mm!! Quote
colwell Posted April 17, 2003 Author Report Posted April 17, 2003 alright thanks. And the bose amp is for sale if anyone wants it. Quote
JS91Z34 Posted April 17, 2003 Report Posted April 17, 2003 alright thanks. And the bose amp is for sale if anyone wants it. How much? Quote
