Robby1870 Posted May 11, 2006 Report Share Posted May 11, 2006 I couldnt find an answer via searching, but where do the drain tubes drain to? I know they run down b/n the doors on a sedan, but do they exit? Quote Link to comment Share on other sites More sharing options...
firefighter_0029 Posted May 11, 2006 Report Share Posted May 11, 2006 I know they Drain right into the Quarter Panel Between the door and the rear wheel on a Coupe. I drilled holes and put longer tubing in my wheel wells so it wouldn't rust out on mine again. Your guess is as good as mine an a Sedan?? Quote Link to comment Share on other sites More sharing options...
Q-Ball Posted May 11, 2006 Report Share Posted May 11, 2006 I have a sunroof on my GP as well. The drains come out on the back quarter panels. The previous owner had work done to the car, and someone didnt like seeing the tubes, so they pushed them back in! No wonder I had major rust holes going through the body. So when I had my body work done, I had carefully pulled the tubes back out and use some sort of caulking so they would stay in place. I believe it was only on the drivers side, I'll have to double check though. But you should see a small hose sticking out infront of your rear tires. It should be about a foot above the bottom of your car. Hope this helps! Quote Link to comment Share on other sites More sharing options...
jeremy Posted May 12, 2006 Report Share Posted May 12, 2006 hey Robby, you posted pics that should answer your question in a thread a long time ago...I found them for you and posted all of them here too Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted May 12, 2006 Author Report Share Posted May 12, 2006 Thanks Jeremy! I forgot I even had/posted those. From the looks of that, one or both of my rear drain tubes are probably clogged. Its supposed to rain for the next like 30 days, but if it clears off one day, I'll take a look at it. Quote Link to comment Share on other sites More sharing options...
