Sorry I am in a HUGE hurry so I didn't have time to search.
I am going to be doing a tune up on my 3100 SFI Cutlass and I need to know the materials I will need.
I know I want to change spark plugs, plug wires, and the fuel filter. The car has 116k miles and I don't know when its had it last tune up. Is there anything else I should replace.
I also need a list of the best (not most expensive but a good product) things to buy. So basically what spark plugs, what wires, what fuel fiiter, and anything else you guys can think of (such as coilpacks.)
Like I said I don't even know if this thing has ever had a tune up. And finally what gap are the spark plugs. Thank you guys (plz dont kill me with the "no search")
AC Delco plugs...the cheapest ones are fine. Autolite wires are decent for the money, and I just use fram fuel filters. Might want to replace the PCV valve too, just because...
I wouldn't replace any coils unless you know you have a bad one. They aren't cheap.
Plugs are already pre-gapped if you buy AC Delcos.
...or if they're not, the gap is listed on your emissions sticker in your engine bay.
which it should be .45( i think..or .045 i cant remember exactly :redface: )
Id use all AC Delco plugs, wires, and filters ( except for the K&N air filter ) I cant remember if the gap is .045 or .060, its been a while since I replaced plugs on my car. but as mentioned above, look there and that will help you out there.
Id just do an oil change while your at it as well.
When I tuned up, I replaced my Spark Plugs (AC Delco, NON-Plat), Plug wires (AC Delco), Oil Filter (AC Delco). If your going for a major tune up, Don't forget your Serp Belt, Gaskets, Coolant, Trany filter/ fluid, PCV valve, Check the vacuum lines, Fuel Filter, And if your getting in deeper.... Fuel Injector O rings, intake gaskets. Don't think it hurts to put new ones on.
Put spark plug socket on spark plug (be sure to remove plug wire first) then turn socket wrench to left (remeber this rule : Lefty loosy, righty tighty)
plug wires,
Soo Easy, just pull them off the spark plug and off coils.
honestly, never done it
:lol: Im just kiddin, but you did say you wanted to know how, know you know LOL :lol: :mrgreen:
you will need a fuel line tool to remove the fuel filter
Nah just two wrenches.
x2. Ive never used a fuel line tool to get that off. just two wrenches and your good to go.
I believe its either a 16 or 18mm flare nut wrench on the steel hard line (don't use a regular wrench) and just use a crecent wrench on the fuel filter. The other side is just a quick disconnect where you push in on the two little tabs.
I would do AC Delco Plugs and OEM wires from the dealer along with a Purolator Fuel Filter. I'd probably seafoam it before doing this and also, if the intake gasket has never been replaced, i'd do that.
the fuel filter should be 20mm....and I guess that I am the only one the used the tool for the quick connects :shrug:....it was only $3 :)
okay well i got a price of $115.00 for the materials for my tune up and they go as follows..
AC Delco plugs - $5.99 x6
AC Delco plug wires - $59.99 (lifetime warranty)
Fram fuel filter - $10.99
PCV Valve - $2.99
Is there anything else I am missing. Also are the plugs .060 or .045 need to know that.
Finally my uncle (an amazing mechanic) is going to help me seeing as this is my first tune up. He wants to know if it is an "in-line" fuel filter, and how hard it is to replace.
thanks alot to everyone who gave me good advice, you are all eally helpful.
okay glad that was established. so does it make it hard to do and how do youdo it on a 3100?
The fuel filter is a simple job, however it may be rusty so you might have to fight with it to get the bolt off. The one "quick connect" or whatever you call it on the one side of the filter is easy though.
Unfortunatly mine was rusted so bad, that the bolt was just stripping and bending the fuel line. I cut it off and put some rubber line along with the new filter and several clamps for good measure...
3100 is a pretty easy engine to work on, only thing I'd suggest is if you are changing your t-stat that you take off the throttlebody. That is all.
1996 and later 3100 spark plugs (according to this manual) Are:: AC type 41-940 or equivalent@ 0.060
I'm not sure if the 94 has a different plug, but the gap is the same..
'94 3100 AC plug is R44LTSM6.
Also when changing the fuel filter, dont take it off all the way until the pressure has been relived. or else youll get a face full of gas
like mentioned earlier, DEFINITELY use a flare nut wrench, not just a normal wrench, to try to do everything to avoid stripping the bolt...
:lol: shhh......that is a secret....
Are those platinum plugs? I would probably just get the stock copper ones, now use spending $5.99 a plug!
When are you doing this? Hit me up, if I have time I could come and help no problem.
FYI...I got the ACDelco wires for my car from GMpartsdirect and they were ~$35 shipped to me....not $60.....and you dont need to replace the PCV valve as long as it rattles.....but then again, it is only $3.
