installed new 3-way vacuum valve +
got full flow back to my vents, still no cruise control. i'm thinking its something in either the stalk, or wiring that runs from the stalk. i also believe the stalk might be fragged, too. haven't had brights for a close to 2 years, i can manually switch them over after removing the wheel and pressing the button myself. also found a red wire that has come out from some harness.it was down behind the air box(which i removed to do the valve) and haven't found its "home." i do have a pic, though on an unfinished roll. any info is appreciated! those are my main concerns at the moment. :mrgreen:
where is that valve? I have the same problem with vents/cruise and I only found one vacum from cruise to engine block. It wasnt cracked.
You said a red wire near the air box? Thats just to check your fuel pump, and it does not plug into anything.
there should be 2 hoses from the cruise diaphram, a bigger hose, then a thinner hose. follow the thinner hose to the valve.
