boostnawd Posted April 16, 2003 Report Posted April 16, 2003 All four hazards corners work, brake lights work. Left signal, only the rear works, right signal, only the front works. On the dash, no left indicator, right indicator works fine. Both indicators work when hazards are turned on. Quote
boostnawd Posted April 16, 2003 Author Report Posted April 16, 2003 Ok, did a little investigative work. I suspect it's the switch in the steering column.. why? Depending on the position of the tilt steering, they will work, also, depending on how hard I push on the stalk, they will work as well. Tough to get at? I suspect I'll need a steering wheel puller.. Quote
toastemcutlass Posted April 16, 2003 Report Posted April 16, 2003 well you fixed your problem but can anybody tell me why when i turn my hazards on the abs light comes on and the abs stops working, other then that the abs works all the time. Quote
Robby1870 Posted April 16, 2003 Report Posted April 16, 2003 yep puller needed. I fixed my switch. New one cost me about $60. Its not too hard though, just need the puller Robby Quote
GnatGoSplat Posted April 16, 2003 Report Posted April 16, 2003 Usually you can clean and bend the contacts out in the switch and it'll last another couple years or so. Quote
