wall21 Posted May 7, 2006 Report Posted May 7, 2006 Ok im lookin at buying a 1990 STE Turbo, the only drawback is that it doesnt have an engine. Does anyone know where i can order one? I havent been able to find any on ebay or searching google. Or any suggestions on what engines will fit. Thanks Quote
Addicted To Boost Posted May 8, 2006 Report Posted May 8, 2006 Every once in a while there is a 3.1 turbo on ebay, but you could probably get away with running a na (non-turbo) 3.1 off ebay or at a junkyard; if you don't mind having less power than the 3.1 turbo. Quote
Guest TurboSedan Posted May 9, 2006 Report Posted May 9, 2006 so this car has NO engine at all? or does it have a bad engine and you just need another one to replace it? where are you located? Quote
Addicted To Boost Posted May 11, 2006 Report Posted May 11, 2006 I found a TGP engine if you're interested click the link below. http://cgi.ebay.com/ebaymotors/1990-1989-TURBO-GRAND-PRIX-ENGINE-3-1L-TGP-PONTIAC-90_W0QQitemZ8065053892QQcategoryZ33615QQrdZ1QQcmdZViewItem Quote
firefighter_0029 Posted May 11, 2006 Report Posted May 11, 2006 Where you at? I know where there's one in PA. Quote
SleeperRed90TGp Posted May 12, 2006 Report Posted May 12, 2006 165# compression, that motor is worn out or he doesn't know how to check compression. Normal 195# Jud Quote
Guest TurboSedan Posted May 12, 2006 Report Posted May 12, 2006 $250 for an old used long block? that's nuts. Quote
