IO_303 Posted May 5, 2006 Report Posted May 5, 2006 I wanted to check my valve clearances tomorrow to see if i can find the taping, I was wondering do i need new valve cover gaskets?? If its anything like my ricemobile then they are rubber and should not be reuse, but if cleaned up right can be with il leaking out later Quote
DiscoStudd Posted May 5, 2006 Report Posted May 5, 2006 3800? If so, they are rubber. A new set is still less than 20 bucks, though... Quote
IO_303 Posted May 5, 2006 Author Report Posted May 5, 2006 3800? If so, they are rubber. A new set is still less than 20 bucks, though... yeah its the 3800, thanks I will pull them and see the condition, and replace if needed. Now i just need to vind valve specs.....hi ho hi ho its off to search i go Quote
GutlessSupreme Posted May 5, 2006 Report Posted May 5, 2006 If they've never been replaced before, go for it. I know I'll probably never change the valve cover gaskets on my 3.1s again though. they just don't tend to leak on those motors. I just did it to be safe because of their age. I can't speak for the 3800 though. Quote
5speedz34 Posted May 6, 2006 Report Posted May 6, 2006 If they've never been replaced before, go for it. I know I'll probably never change the valve cover gaskets on my 3.1s again though. they just don't tend to leak on those motors. I just did it to be safe because of their age. I can't speak for the 3800 though. Nearly ever 60* motor I've seen leaks from the valve cover. Quote
IO_303 Posted May 6, 2006 Author Report Posted May 6, 2006 My valve covers were worse than that....i need to clean the engine bad....let just say when i got the car I thought it had black vlave covers, and yesterday i found out diffrent Quote
digitaloutsider Posted May 6, 2006 Report Posted May 6, 2006 The ones on my Regal are leaking profusely. I need to the job VERY soon. I just don't have the money yet. Quote
IO_303 Posted May 6, 2006 Author Report Posted May 6, 2006 it cost me a total af $16 and 3 busted knuckles Quote
john99gtp Posted May 6, 2006 Report Posted May 6, 2006 valve covers are mad easy if i can do them, anyone could and i can do rockers and.......an engine swap! =p Quote
