94CutlassXtreme Posted May 4, 2006 Report Posted May 4, 2006 Yeah so I glanced down at my temp gauge today and it was creeping over towards the red. I tried revving it and it didnt go down. When I got home, I checked the coolant, its fine. The oil isnt milky either. The intake gaskets, water pump, and I believe the thermostat were all done about 5 months ago. There are no external leaks. Any suggestions? Quote
SigEpCutlass Posted May 4, 2006 Report Posted May 4, 2006 TCS or the fans are dead. A bad TCS will prevent the fans from turning on. Obviously, if the fans don't turn on at the temperature they should, your car's going to run hot. I have a similar problem right now. I haven't had a chance to fix it. I'd still check the upper radiator hose to make sure it's hot. If it's hot with the coolant flowing through it, then you know the thermostat is open as it should be at the higher temps. Quote
94CutlassXtreme Posted May 4, 2006 Author Report Posted May 4, 2006 What exactly do you mean by TCS? I just checked it out again. It got hot and the thermo didnt open, it stayed hard as a rock packed with coolant at around 260. And the secondary fan came on, but not the primary. Quote
SigEpCutlass Posted May 4, 2006 Report Posted May 4, 2006 TCS either stands for Temperature Control Sender or Temperature Control Soleniod...I can't remember which. Either way, if the the thermostat didn't open, then there's your culprit. The primary cooling fan is the on the passenger side. The secondary fan (hooked to the A/C compressor) is on the driver's side. This is all coming from memory, so if I'm wrong, someone please correct me. Quote
97loudcut Posted May 4, 2006 Report Posted May 4, 2006 your right from what I've heard and also from the 3100's ive delt with it usually is fan failure. Quote
GP1138 Posted May 4, 2006 Report Posted May 4, 2006 What exactly do you mean by TCS? I just checked it out again. It got hot and the thermo didnt open, it stayed hard as a rock packed with coolant at around 260. And the secondary fan came on, but not the primary. Dude, if your thermostat didn't open, that's the first thing I'd replace. Quote
SigEpCutlass Posted May 4, 2006 Report Posted May 4, 2006 ...Either way, if the the thermostat didn't open, then there's your culprit. Quote
Dirty Rockstar Posted May 4, 2006 Report Posted May 4, 2006 ...This thread helps! My 94 has been doin some goofy shit on the temp. front.. But my fan comes on! Quote
94CutlassSLCoupe Posted May 4, 2006 Report Posted May 4, 2006 on my car i usually can't tell that the fans are on until 225 degrees (as indicated by my DIS)...Might do the manual cooling fan switch mod just to keep the temps down a little. Quote
5speedz34 Posted May 5, 2006 Report Posted May 5, 2006 TCS either stands for Temperature Control Sender or Temperature Control Soleniod...I can't remember which. Either way, if the the thermostat didn't open, then there's your culprit. The primary cooling fan is the on the passenger side. The secondary fan (hooked to the A/C compressor) is on the driver's side. This is all coming from memory, so if I'm wrong, someone please correct me. Coolant still flows through the motor through a bypass right? FWIW: If your car gets into the red turn the heat of full! Quote
94CutlassXtreme Posted May 5, 2006 Author Report Posted May 5, 2006 Where is this TCS located? And is everyone sure the primary fan is on the passenger side? I would have assumed it was on the drivers side? Quote
19Cutlass94 Posted May 5, 2006 Report Posted May 5, 2006 Its located on the drivers side, almost right below the TB. Just after the dogbone, youll see a couple wires running down. They run down to the LIM by the themostat. BTW, I believe its a 15mm to get it out. Quote
94CutlassXtreme Posted May 5, 2006 Author Report Posted May 5, 2006 lol ohh, you mean the ECT (engine coolant temp) sensor. I just picked one of those up tonght. I'll give it a shot in the morning. Quote
SigEpCutlass Posted May 5, 2006 Report Posted May 5, 2006 lol ohh, you mean the ECT (engine coolant temp) sensor. I just picked one of those up tonght. I'll give it a shot in the morning. Wait, are you talking about what Jay said above. Is that what you replaced? Quote
