perfecseal Posted May 4, 2006 Report Posted May 4, 2006 Ok its time for me to install a new fuel pump and so i did some looking around and found that all the local parts stores have the same thing... Stock for around 50 bucks orEDELBROCKs HIGH PERFORMANCE IN-TANK; FUEL PUMP; 1985-1992 FUEL INJECTED GM; NON-TBI; 67 GPH... For 145.00$$ so is it worth it to buy this so called high performance pump.. I dont have much to go on to compare Quote
TGPilot Posted May 4, 2006 Report Posted May 4, 2006 I just got my Walbro today. Ordered it late on Monday and arrived today. Will be draining the fuel out tonight and starting the replacement process tomorrow evening. Quote
Garrett Powered Posted May 4, 2006 Report Posted May 4, 2006 I got a lifetime warranty one, lemme tell you it payed itself off. Quote
TGPilot Posted May 4, 2006 Report Posted May 4, 2006 That was fun...only took me 1 hour to get 16 gallons of gas out of the car!!! The pump is running and flowing fuel...but it is just barely streaming out! Should be like a fire-hose shouldn't it? I was using a 3/16" hose with a threaded barb on a brand new filter. Quote
mfewtrail Posted May 4, 2006 Report Posted May 4, 2006 If you're looking for an OEM replacement, buy from here. These usually run a good $20 more at parts stores(autozone was the only retailer around here that even carried AC Delco pumps besides the stealerships....) http://cgi.ebay.com/ebaymotors/NEW-AC-DELCO-FUEL-PUMP-KIT-EP375-25163463-FE0110_W0QQcmdZViewItemQQcategoryZ33555QQitemZ7990189267QQrdZ1QQsspagenameZWD1V Our stock fuel pumps are more than adequate for most TGP's. Quote
