blkinternational Posted May 3, 2006 Report Share Posted May 3, 2006 i did a search and i still cant find what im looking for......my dashlights still are not working ive come to the conclusion that its a short because everyonce and awhile they will go on and work untill i do somthing that takes power..like putting car in reverse or turning radio on... can somone please help me? Quote Link to comment Share on other sites More sharing options...
SigEpCutlass Posted May 3, 2006 Report Share Posted May 3, 2006 Check all the fuses in the glove box? If you pull the cluster do you see any loose connections or frayed wires? Quote Link to comment Share on other sites More sharing options...
89GP_SE Posted May 3, 2006 Report Share Posted May 3, 2006 check your fuses. I had that issue with that once in my GP. I found out it was the ELCT. fuse didnt even knew I had one. Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted May 3, 2006 Report Share Posted May 3, 2006 Check the CRTSY fuse. If that doesn't work I would start by checking out the plug that goes into my cluster. Quote Link to comment Share on other sites More sharing options...
fastbird232 Posted May 3, 2006 Report Share Posted May 3, 2006 checking out the plug that goes into my cluster. http://www.w-body.com/forum/index.php/topic,41417.0.html Quote Link to comment Share on other sites More sharing options...
