GOT2B GM Posted May 1, 2006 Report Posted May 1, 2006 Are these a direct bolt on for the LG5. Do they use the original length LG5 pushrods? What donor motors can I get the rockers from? (I'll probably just use factory stamped 1.6 rockers) And lastly, what if any modications are needed to accomodate the 1.6 rockers? Thanks Quote
GutlessSupreme Posted May 1, 2006 Report Posted May 1, 2006 Use the original pushrods. You can get them from '95ish 3100 motors (not sure exactly). Make sure you get the studs and all too. No mods should be needed for the 3100 stamped ones. Quote
GOT2B GM Posted May 1, 2006 Author Report Posted May 1, 2006 So should I get the studs, rockers and balls? If someone could clarify the exact model year range that the stamped 1.6 rockers came in the 3100, that would be appreciated. Quote
