97 Grand Prix 3100 Vacuum Help Needed
We bought a 97 GP Se with the 3100 and on the back of the intake manifold,it was missing the vacuum line thats found on the top of the plenum,passenger side.I found another broken vacuum line hanging down under the carat the back of the engine,But also found another broken vacuum line coming up where the washer fluid tank is.Is there supposed to be a T fitting or check valve to connect these 2 lines to the back of the manifold?
There was a problem with the a/c not blowing out the correct vents as well...Im familair with these problems on other GM cars but this is new to me with this engine.The broken vacauum line in back of the engine looks like it goes inside a wire harness or somewhere back there...hope this helps explain it a bit.Sorry cant take pics of the stuff.Just need to figure out what goes where.
[br]Posted on: April 28, 2006, 11:30:16 PM_________________________________________________I forgot to add that at the back of the intake plenum,the vacuum port according to the vacuum underhood sticker is a acsry port.Is there supposed to be a check valve back there?It doesnt show anything else.
Thanks.
[br]Posted on: April 29, 2006, 01:42:43 AM_________________________________________________Update,I found where the line went and doesnt appear to be a check valve back there....theres a check valve under the washer fluid reservoir and that line was supposed to run over the strut tower,along the firewall and to the back of the plenum...when the line broke in half,some of it went down and appeared to go into a wireharness back there but was just sitting there.All is well!
:lol:
