RedZMonte Posted April 14, 2003 Report Posted April 14, 2003 I drove to salt lake city Sat. and picked up my car. Its a 1990 TGP. It needed a fuel pump. I put it in sunday. I AM NEVER DOING A FUEL PUMP on any of my cars ever again! it was the biggest PITA i have had to do on my cars. But sunburnt and greasy head to toe and 4 hrs later its in. The cars started right up. It misses after 3,000RPM so i am doing a full tuneup and changing ALL the fluids and a tranny service. I allready like that car allot. I will let you guys know what it runs like after a full service. BTW how much boost is does it run stock? Does anyone have a pic showing the Boost controler (on the front valve cover) that the turbo and wastegate connect to, i want to double check to see if it is hooked up correctly to the vaccume lines. I took the Intake arm off (open trubo) and it sounds SWEET! 147,500 miles and the trubo has 0 wheel play . I think the X-over may be leaking.. so that is 1 more thing i am not looking foward to removing. Shane "RedZMonte" 1995 Monte Carlo Z34 (LQ1) 1992 Lumina Z34 (L67) 1990 Turbo Grand Prix (LG5) Quote
Guest Anonymous Posted April 14, 2003 Report Posted April 14, 2003 I have 177,000 miles on mine and it has no wheel play either. Quote
RebelGT Posted April 14, 2003 Report Posted April 14, 2003 http://www.villagephotos.com/pubbrowse.asp?selected=117677 bottom rightish diagram. Quote
RedZMonte Posted April 14, 2003 Author Report Posted April 14, 2003 http://www.villagephotos.com/pubbrowse.asp?selected=117677 bottom rightish diagram. http://www.villagephotos.com/image.asp?id_=1937368 Sweet that is exactly what i need. they both are currently connected to the right side of the wastegate sullinoid side w/ a "T" I knew it didn't look right. So hopefully this will take care of my boost issues. Shane Quote
twalt13 Posted April 14, 2003 Report Posted April 14, 2003 Shane, Look forward to seeing it, that will make 4 turbo GP's in the RMCGP. I should be home in a month or two. Thomas Quote
