luminal67 Posted April 26, 2006 Report Share Posted April 26, 2006 i was going to seal the nuts that hold my tail lighs in with silicone to stop a trunk leak, and I found something interesting. Unfortunately, my car is rusting bad inside where the end of the quarter panel curves around the back. Inside there, is a seam that sticks up like a fin that has that factory sealer gooped on it. Well i peeled some of it off to see more rust, and when I did, there happened to be a hole where three panel come together. Not a rust hole, it was there from the factory. I could see considerable light through it and it had a rust stain that showed that it was dripping down. so I took some of my silicone and tried sealing it up. we will see how well it works next time it rains. This is on my Lumina and i am unsure how it might work on a GP, cutty or regal. I hope this sheds some light on this VERY annoying subject. -Brian- Quote Link to comment Share on other sites More sharing options...
1990lumina Posted April 27, 2006 Report Share Posted April 27, 2006 Cool....I resealed my whole f'in trunk a month ago.....no leaks since!!! Hope you found your problem Quote Link to comment Share on other sites More sharing options...
White93z34 Posted April 29, 2006 Report Share Posted April 29, 2006 when i got my car it leaked BAD on the drivers side where the wheel well and quater pannel met, and i put a mess of silicone in the seam and it has held up great for a long time now. Quote Link to comment Share on other sites More sharing options...
luminal67 Posted May 1, 2006 Author Report Share Posted May 1, 2006 well it's raining tonite, so it should be a good tet to see if it is fixed[br]Posted on: April 30, 2006, 09:51:03 PM_________________________________________________I looked in the trrunk this morning and one side is dry and one is wet. I'm gonna double check the left side to see if i missed something, but the right side worked. Quote Link to comment Share on other sites More sharing options...
3pt1lumina Posted May 2, 2006 Report Share Posted May 2, 2006 I gave up. Glad you figured yours out. Quote Link to comment Share on other sites More sharing options...
luminal67 Posted May 2, 2006 Author Report Share Posted May 2, 2006 well it's been raining for about 2 days and i looked in my trunk and it's all wet still. I think since i have so much rust around that area inside, that it does no good to block the one hole. It will find it's way in however it can. The only way i think that I can really fix the leak, is to fix the rust first. Quote Link to comment Share on other sites More sharing options...
