i have used the search funtion to find pinouts for the 89 ub3 but i need pinouts for a 94 analog set. does anyone know what they are? i am putting 94 analog guages in my 89 cutty. these are the guage cluster i am trying to install 726182_59_full.jpg this pic is from another post but i have the same gauge cluster.
does your car have the base model dash in it or a ub3? if it has just the speedometer and idiot lights it will plug right in and all you will have to do is run the tach wire to a white wire on the ICM. then replace the switches with sensors.
it has the ub3 like the one in your sig. does anyone know what the tach wire is on the ub3 harness?
the analog dash is not a direct swap then and i do not know how you are going to swap it in you should talk with stockgp about an adaptor. The Ub3 tach wire will not work for the analog dash I found that out so you need to run a wire for the white wire on the ICM connector.
thank you all for your input, i did the swap yesterday in my high school parking lot :lol: i missed the buss to my afternoon class so i had 4 hours. thanks ToroToro for the pinouts. i have one crappy picture of them at night but i will get a good day shot as soon as i can. the tach wire i had to run to the icm it was a purple wire.
That does look alot better than what you had on there before!!!! Good work
hey wait a sec, thats my picture of the cluster. Glad someone else changed over to this style, SCREW DIGITAL :twisted:
