My GTP 1994 manual swap.. more pics... (warning 56K)
ta gueule, tapette!
quote of a BIG Looser.. If your are not able to talk with matturity ... don't post on my topic please .... I'm here to shown pic of my swap to shown a poeples who can make a swap ... I know it's not the BEST way to pull out the engine ... I'm not equiped to pullout a engine for the floor .... It's look very more dangerous on in pic that actually....
thank's for the good commentary .. I apreciate ! ;)
Be careful while working with the car up like that. Good luck with the swap.
It's last summer I jack my car this 'position' .. the car is on a scrap now... I keep only what I want to make my swap .. I continue this spring .....
today I was "unplug' tranny of the engine :P and keep all tranny suport :)
I will shoot my tranny in a garage just to check it if It's in good condition to go on my GTP :)
I esperate !!!
[br]Posted on: April 30, 2006, 03:27:13 AM_________________________________________________well.. I was continued in this weekend :P
unbolt tranny, clutch, pressureplate and the support.. :)
The tranny GeTrag HM-284
My friend .. lol
tranny support
flywheel - clutch - pressureplate
next weekend !! :)[br]Posted on: May 02, 2006, 02:52:11 AM_________________________________________________new pics added ! :P
Hey Brian, I think I might have asked you before but what is your knowledge for wiring in the Clutch Start Switch and Shift Anticipate Switch? I want to get these wired in on my 5 speed swap. I'm doing a swap on my 93 GTP.
no problem let me know if i can be any more help
i never added those in. never had a need for it. it is not that hard though. you just need the secematic
  • 4 weeks later...
YESS !I have continued at this weekend ... :P
I rent a moter holder to putout on my GTP ..
My GTP before
Hood remouved
Prestone flush, and unplug all
coil out (I find a intrax coil to change it :P
some beer .. hot day
GO !
humm ...
(sti de bo coup de soleil a la fin de la journée..)
humm ...
It's so big engine !!! don't pass in the hole...
well .. lol
oupss, some plug, unplug
engine bay
clean and wax :P
engine and tranny
what's wrong on this pic ??
oupss ....
tranny pull out
For Sale !! very cheap !! lolol
continue Next time !!!
Yann
lol Ya ...
this hole is for a better transmission cooling ... lol
don't heating :P
quand le pensez-vous aurez-vous lieu sur la route ? Sorry for the bad French i speak English! :lol:
  • 4 weeks later...
this is my new pics ... sorry it's long between each post .. :(
time to remove my dash :)
pedalmount automatic
automatic and manual
humm :S lol
well :P
the firewall plate remove
Automatic versus Manual
automatic
manual
the hole is not the same .. just change to plate .. that's it :)
clutch cables hole
my new clutch, pressureplate, and flywheel :)
50% ceramic and 50% cevlar
well .. the pedalmount of manual car it's not 100% same of automatic ... and don't fit very well in automatic hole ...
I decide to keep my manal pedal .. and fit on my automatic pedalmount .. very more simple to make this change of grind the strut under the dash ... :)
pedalmount done :P
brake booster of my Z34 less big of brake booster of automatic ...
this is for the clutch cylinder hole
with the brake booster of automatic .. the clutch cylindre don't pass
shifter done
more pics soon :)
Voulez vous faire le mien?? ça semble que vous saviez quoi faire. :razz:
glad you got your pedal-mount problem solved!!!! - Crazy K
and.... was that automatic transmission still working even with the hole???????
no ... 2little gear in it was broken ...
in the differential.. 2 big gear in each side .. and 2 small perpendicular .. this 2 gear ..I find in pieces on my suspention table ... lol
It was in neutral on each speed and all oil on the floor ...
Thats exactly what the trans on my cutlass looked like when I bought it. :lol: Thats why I got it for only 500$, including a valid safety inspection. He was quoted close to 2000 to fix it and just wanted it out of his sights. I put in a weekend's worth of time, 290$, that includes rebuilt diff, enough trans fluid to do a flush, trans filter, new diff housing, engine oil and filter and plugs. I had thought about doing a 5pd swap, but I want to turn my regal into my project car, and I really dont want a 5spd daily driver. I just might end up throwing a 5 spd into the regal instead, and quite possibly a DOHC as well. :razz:
