rear suspension oil leaks
Guest RedCutlassSL
i noticed today there are 2 oil spots right by my rear tires. I looked, and the suspension pieces are shiny from oil. I also noticed one of the dust boots covering the strut itself is missing. could this be causing my shudder during right turns? what do i need to fix this? thanks
are your struts the OEM one's? if so there probibly leaking and need to be replaced.... there ont hard @ all to do either so your in luck (that is unless the upper strut bolts deside to break).......
reach up around the strut shaft and feal if its wet or not, if it is, that where its coming from.... your car is prolly pretty floaty to.. lol
later
joe
yeah it does. You might consider going with coilovers, Dustin, just a thought
Robby
