line that runs into the rad...
Ok ive been have this lil drip under my car for a week and its getting worse... I looked under the car and its coming for the driverside of the rad and it the bottom METAL hose thats leaking. Well i cant tell if its the hose or the huge nut that goes around it. Is this an oil cooler/trans oil cooler? What is the part number for the hose and nut? The tank on the rad does not looked cracked.
Your crazy. Don't mess with it. That could be your AC line. Check your upper radiator hose and around it for cracks. HAHA!!! You have a plastic radiator.
UPGRADE!!!! :rolleyes:
:iamwithstupid:
Its not my AC... The AC does not leak oil and yes the tanks on most stock radiiators are plastic. No need to upgrade to full aluminum on a stock motor. No its not leaking coolant so theres no need for me to check my upper radiator neck.
Ok no more comments from that guy please. :bonk:
