Seshomaru7 Posted April 23, 2006 Report Posted April 23, 2006 Is it a good idea to mount black lights on your sub box? Will the rattling break the lights? Also, how do you get the lights to brighten up and dim, according to how the subwoofers play? Quote
19Cutlass94 Posted April 23, 2006 Report Posted April 23, 2006 I duno why it would be a good idea to do that? the rattle wont break anything, just be very annoying, and you can splice into the trunk light, the power wire and just ground it. Quote
Seshomaru7 Posted April 23, 2006 Author Report Posted April 23, 2006 I duno why it would be a good idea to do that? the rattle wont break anything, just be very annoying, and you can splice into the trunk light, the power wire and just ground it. No, I mean, when the bass hits, the lights power up from dim regularly. I've seen it done, just don't know how. Quote
19Cutlass94 Posted April 23, 2006 Report Posted April 23, 2006 you mean like a light that goes with the bass? Quote
Seshomaru7 Posted April 23, 2006 Author Report Posted April 23, 2006 you mean like a light that goes with the bass? Yep. I saw it done at a car show. He had bright blue lights in the trunk. Quote
Darksyde Posted April 23, 2006 Report Posted April 23, 2006 Every walmart and pepboys carries the little module to make your neon's go with the bass. I had one it was like $10. I also used blacklights in my trunk. Never had a issue with breakage from the bass. It did however rattle them out of the holdr a cpl times. I had to glue them in. Quote
Seshomaru7 Posted April 23, 2006 Author Report Posted April 23, 2006 Every walmart and pepboys carries the little module to make your neon's go with the bass. I had one it was like $10. I also used blacklights in my trunk. Never had a issue with breakage from the bass. It did however rattle them out of the holdr a cpl times. I had to glue them in. Do you wire the lights into the sub wires or from the amp? Does it take away much power from the subs? I think it would look cool if i used black lights in my trunk. Quote
19Cutlass94 Posted April 23, 2006 Report Posted April 23, 2006 hijack........Darksyde, your avatar looks like it woulda hurt   hijack over, continue Quote
Seshomaru7 Posted April 23, 2006 Author Report Posted April 23, 2006 hijack........Darksyde, your avatar looks like it woulda hurt   hijack over, continue ROFL Quote
Darksyde Posted April 23, 2006 Report Posted April 23, 2006 The module detects sound and vibration. It does not connect to the speakers or amp in anyway. The neon's however need to be hooked to the module, obviously. The power lost from neon's are very very small. Quote
Seshomaru7 Posted April 23, 2006 Author Report Posted April 23, 2006 The module detects sound and vibration. It does not connect to the speakers or amp in anyway. The neon's however need to be hooked to the module, obviously. The power lost from neon's are very very small. So what way are the lights powered? Wired to the battery? Quote
Darksyde Posted April 23, 2006 Report Posted April 23, 2006 lol oh yea the neons....well mine started their life with cigarette lighter adapters on them. I ended up cutting that off and running the ground to steel in the trunk and the power to the blue amp feed on the amp. Quote
Puggsley456 Posted April 23, 2006 Report Posted April 23, 2006 I've seen some cool things done with LED's inside the subwoofer box. But It only works if the cone of the sub is a light color. Quote
Garrett Powered Posted April 23, 2006 Report Posted April 23, 2006 well if its rattling enough to break the glass then just reinforce the faceplate. double or triple layer it with glass or medite or both. I got 5 1/2" thick faceplate and you put your hand on it at full volume and its dead. Quote
