Removing the rear exhaust manfiold?
Any helpfull suggestions on how to get that biatch off? do i have to remove my plennum? can i get the lower ones from under the car? 1995 Monte Carlo Z34 3.4L DOHC. I have the Front manfiold, X-over and Downpipe allready off. I just need to get that rear biatch off. i figure i might be able to sag the rear subframe bolts down and get at it, what do you think?
RedZ
I would say, take the plenum off, although you'll prolly have to get a new gasket set for it. I mean, either way you try to do it, its gonna be tough. Theres really no easy way to do it. With the plenum off, you can rock it forward a little, to get to the rear manifold. Like I said, either way its gonna be tough
Robby
I'm thinking MAYBE you could get to the exhaust manifold by lowering the rear of the subframe. I seem to remember it was no trick at all to get the downpipe off the manifold. Maybe if I had to, I could have reached a bit higher with some fancy extensions and got the rest of the manifold bolts out.
On the other hand, think there will be bolts on top, so you'd have to reach over the exhaust manifold. I don't know that lowering the subframe would give you enough clearance for that. You might end up having to do both!!! Pulling off the plenum to get the exhaust manifold bolts off, and lowering the subframe to get the down pipe bolts out.
pull the engine out!
Hehe, I did... Though it was more I was afraid of catching my car on fire while welding the exhaust.
im not to sure on certain subjects....for example, when you mentioned welding of the exhaust manifold do you mean to the block? i thought i saw a fiero wit headers on a 3.4 wit the headers welded onto the block...just curious
I'm putting a turbo on it so I need to weld up a crossover and downpipe for it.
And those pics you saw, the headers were not welded to the block, they were welded to flanges which then bolt to the heads
I'm assuming the 96 would be the same, Hope this helps.
Document ID# 57339
1996 Chevrolet/Geo Monte Carlo
Exhaust Manifold Replacement Right Side
Removal Procedure
Remove the air cleaner duct. Refer to Engine Controls.
Remove the exhaust crossover pipe. Refer to Exhaust Crossover Replacement .
Disconnect the EGR tube from the exhaust manifold.
Raise and suitably support the vehicle. Refer to General Information.
Remove the front exhaust pipe and the converter assembly.
Remove the oxygen sensor.
Remove the exhaust pipe front heat shield.
Remove the rear generator brace.
Remove the transmission dipstick tube.
Remove the intermediate shaft from the steering gear. Refer to Power Steering Gear and Pump.
Remove the exhaust manifold nuts.
Install the jacking fixture in order to support the rear cradle.
Remove the rear frame bolts.
Lower the frame.
Remove the steering gear heat shield. Refer to Power Steering Gear and Pump.
Remove the exhaust manifold and heat shield.
Remove the exhaust manifold gasket.
Clean the gasket mating surfaces.
If the exhaust manifold is being replaced, transfer the following parts:
The studs
The heat shield
Installation Procedure
Install the exhaust manifold gasket.
Install the exhaust manifold and heat shield.
Install the exhaust manifold nuts. Tighten
Tighten the nuts to 13 N·m (115 lb in).
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the steering gear heat shield. Refer to Power Steering Gear and Pump.
Raise the frame.
Install the rear frame bolts. Refer to Body Dimensions and Underbody.
Remove the jacking fixture.
Connect the intermediate shaft to the steering gear. Refer to Power Steering Gear and Pump.
Install the transmission dipstick tube.
Install the rear generator brace.
Install the exhaust pipe front heat shield.
Install the oxygen sensor.
Install the front exhaust pipe and the converter assembly.
Lower the vehicle.
Connect the EGR tube to the exhaust manifold.
Install the exhaust crossover pipe. Refer to Exhaust Crossover Replacement .
Install the air cleaner duct.
Document ID# 57339
