luminal67 Posted April 20, 2006 Report Share Posted April 20, 2006 has anyone ever changed one of these or bought one new? how hard is it to change. mine has alot of slack and you need a person to pull up on the hood while someone pulls the lever to open the hood. it sucks Quote Link to comment Share on other sites More sharing options...
mcbfarm Posted April 20, 2006 Report Share Posted April 20, 2006 Go get one. The worst part is getting under the dash and threading the thing through the hole in the firewall. Trace backward from the hood latch to locate the hole and position someone with a flashlight outside aimed in through the hole when you're under the dash and pull the cable out, and you'll see where it goes. This is after it's loose on both ends. If yo have no manual go get a Haynes for your year and model, about $15 and does most everything. If you're serious, check out alldatadiy.com . Quote Link to comment Share on other sites More sharing options...
