Has anyone removed or painted over the red stripe along the bumpers and trim on Lumina Eurosports? I'd much rather have a solid black car, than have the red stripe around the whole car like a big ugly pinstripe. I'm wondering if it's easier to remove the material or just paint over it.
IIRC that red is paint....underneath is silver if I remember. with that in mind I'd sand the red a bit to get it rough, tape off everything and paint over the red a few times...
I'm pretty sure its red tape because i've pulled i off a car in the junk yard. It looked like the trim from a base lumina underneath.
That red trim is just black rubber trim with red vinyl on it. Mine has turned pink, and I plan on laying new red vinyl over it.
it'll probably be kinda hard since it had to stay on the car for along time...just use a heat gun(or hair dryer) and heat it up, then it should just peel off with little to no trouble
Thanks much. I think I might try it. I really dislike the red stripe.
i took mine off. it's alot harder to remove than pinstriping...lol!
i just pulled like a mother and it finally came off, but it left some white shit behind it so you might have to get a hair dryer and some googone to get that shit off. not too hard otherwise.
Would it be easier, or even practical, to just paint it black?
Maybe, but if you don't prep it right the paint probably won't stick properly
