Oil return to pan
hey guys,
recently my car has developed a leak from the oil return line, where it returns into the oil pan. i know its not from the pan itself, and its not leaking down the return line and dripping off at the bottom, its from where the metal line goes into the pan. i was wondering if there is any easy way to get to that to either tighten it or remove it to put in some ATV or something. the bottom nut looks easy enough but what about the top? i really dont feel like pulling the pan and all that good stuff...
thanks guys
mitch
You should beable to get at it from underneath. You prolly will have to take oil filter off. If you still can't reach take the oil cooler off and all of that other crap up there, then you should see it real easy. But the lines to the oil cooler are a b**** to get out. Goodluck
Ryan
