IRONDOG442 Posted April 15, 2006 Report Posted April 15, 2006 Hey guys i'll post some pics, quess what i am doing.?.. this car will be for sale soon... I know you all want it. 1995 CS coupe dark teal metaillic with charcoal cloth, (unless someone sells me cheap nice leather) CD player 125,000 miles. New upper everything Including head gaskets !! Will run great I promise! 3.4 Liter 5 star wheels... new brakes ALL ... new tiger paw tires... Tell me men? what it is this worth?? I am putting a shit load of work into it!! Quote
Psych0matt Posted April 15, 2006 Report Posted April 15, 2006 between 2 and 3k, probably a little more around 3 if its in good enough condition Quote
SigEpCutlass Posted April 17, 2006 Report Posted April 17, 2006 does that look really dirty, or is it just me? Quote
Regal_GS_1989 Posted April 17, 2006 Report Posted April 17, 2006 does that look really dirty, or is it just me? Nope, its not just you. It looks sludged up to me. Quote
19Cutlass94 Posted April 17, 2006 Report Posted April 17, 2006 I just got done doing that. Fucking gaskets.... But that does look very dirty, and possibly sludged up like said. Looks very different from my engine. I lifted that lower intake, and it was like heaven. So nice and clean in there! That picture doesnt look good... Quote
brianteel Posted April 17, 2006 Report Posted April 17, 2006 keep the motor and trans and i will give oyu $500 Quote
IRONDOG442 Posted April 18, 2006 Author Report Posted April 18, 2006 Dont worry about sludge boys, IRONDOG here is cleanin her out in a parts washer. heres some pics of the pistons the cylinder walls look GREAT !! thats about the only good news I have had on this job. F-in gaskets!!! The tranny shifts solild too!! I am changing spark plugs, head bolts, plug wires, thermostat, MAP sensor, PCV valve, air filter, valve guides, cleaned injectors, oil filter, anti freeze, parts washed all hard parts, including valve covers and rocker arms, ALL upper gaskets and head gaskets. anything I am missing?? Quote
19Cutlass94 Posted April 18, 2006 Report Posted April 18, 2006 valve seals, check to see if a valve is burnt or not, oil pump drive seal o-ring, I know Im forgetting something.... Quote
Pabz Posted April 18, 2006 Report Posted April 18, 2006 Exhaust Manifold Gasket Set - Dont want to make the same mistake i did Quote
19Cutlass94 Posted April 19, 2006 Report Posted April 19, 2006 might as well replace the IAC, mine was all fucked up... Quote
5speedz34 Posted April 19, 2006 Report Posted April 19, 2006 TPS, IAC, I would get a head set(all the gaskets from the heads up) and get the heads rebuilt with new seals. Quote
IRONDOG442 Posted April 20, 2006 Author Report Posted April 20, 2006 Yes of course I bought a complete gasket set for heads all seals were replaced . I also did an oil pump drive seal and exhaust manifold gaskets. Here's a low resolution pic I took with my phone after I put the heads back on. Quote
19Cutlass94 Posted April 21, 2006 Report Posted April 21, 2006 That looks much better! now once you get that engine back together, use a good oil so you wont get that black shit ( looks like sludge ) Quote
