Bake82 Posted April 14, 2006 Report Share Posted April 14, 2006 Hey guys, I'm completely stripping a 92 CS of it's interior on Tuesday. I am wondering what special tools I might need. I will be taking all seats, panels, dash, doors, seatbelts, carpet, console. Everything in the interior. Anyways I don't want to get down there(5 hour drive) and then not have the proper tools to take off everything I need. any and all tips are appreciated. Thanks Kyle Quote Link to comment Share on other sites More sharing options...
kuntzie Posted April 14, 2006 Report Share Posted April 14, 2006 phillips screwdriver 7mm socket 15 mm socket 1/2" socket 5/32" socket ( or 8mm i think)- the seats some extentiom bars 10mm socket flat head screw driver brind a small but long flat screwdriver, or a 6 mm alen key... you gotta wede it into the top of the seatbelt to loosen it off (at the to of the window) 1/4 socket ill add more as i remember oh ya a T-45 torx bit for getting off the seatblet part that clamps onto the ground and a 18mm for the rear seat belt clamp dow an 11 mm for the back, upper side of the seat i think thats about it edit you will also need a 10 mm or 12 mm deeap socket for the rear tails if u get them also just to let you know this guy has about 4 tool boxes in his garage so im sure hes got everything... i was jelious Quote Link to comment Share on other sites More sharing options...
97CuttySupSL Posted April 14, 2006 Report Share Posted April 14, 2006 phillips screwdriver 7mm socket 15 mm socket 1/2" socket 5/32" socket ( or 8mm i think)- the seats some extentiom bars 10mm socket flat head screw driver brind a small but long flat screwdriver, or a 6 mm alen key... you gotta wede it into the top of the seatbelt to loosen it off (at the to of the window) 1/4 socket ill add more as i remember oh ya a T-45 torx bit for getting off the seatblet part that clamps onto the ground and a 18mm for the rear seat belt clamp dow an 11 mm for the back, upper side of the seat i think thats about it edit you will also need a 10 mm or 12 mm deeap socket for the rear tails if u get them also just to let you know this guy has about 4 tool boxes in his garage so im sure hes got everything... i was jelious have fun bake Quote Link to comment Share on other sites More sharing options...
ToroToro Posted April 14, 2006 Report Share Posted April 14, 2006 Seats are 8mm. You'll also need a 12mm for the console IIRC. Quote Link to comment Share on other sites More sharing options...
Bake82 Posted April 14, 2006 Author Report Share Posted April 14, 2006 Cool, thanks guys. I have a 300pc ratchet set that I'm gonna bring. Was just curious what else I might need. What do I need to get the seatbelts out of the doors??? Quote Link to comment Share on other sites More sharing options...
ToroToro Posted April 14, 2006 Report Share Posted April 14, 2006 The door panel comes off in two different pieces. The lower part around the seatbelt unscrews and unclips. Then you pry the little trim thing off the top of the door around the seatbelt, and unscrew the panel up there. Then you can take off the door panel and the seatbelt slides out around it. The whole seatbelt assy. just unbolts from the door after that. The seat belt never actually goes "into" the door, just behind the door panel. It's tough to explain but I'm sure once you get out there you can figure it out easily. Quote Link to comment Share on other sites More sharing options...
Bake82 Posted April 15, 2006 Author Report Share Posted April 15, 2006 The door panel comes off in two different pieces. The lower part around the seatbelt unscrews and unclips. Then you pry the little trim thing off the top of the door around the seatbelt, and unscrew the panel up there. Then you can take off the door panel and the seatbelt slides out around it. The whole seatbelt assy. just unbolts from the door after that. The seat belt never actually goes "into" the door, just behind the door panel. It's tough to explain but I'm sure once you get out there you can figure it out easily. Cool. I've had my door panels off before, so I know how they come off...kind of weird the first time, that is for sure. It was the seat belt assembly that I was worried about, but it sounds like it's easy enough. Thanks man!!! Quote Link to comment Share on other sites More sharing options...
kuntzie Posted April 15, 2006 Report Share Posted April 15, 2006 ya seatbelts are 15mm, 5 nuts in total per belt, the ones in the rear are a 45 or t -50 though ( my 89 had -t50and the blue gtp i got had t-45 torx)..... the whole interior to strip down only took me about 3 hours, but ive done it 4 times now lol Quote Link to comment Share on other sites More sharing options...
cutlsp Posted April 15, 2006 Report Share Posted April 15, 2006 the whole interior to strip down only took me about 3 hours, but ive done it 4 times now lol I've done the cutlass interiors about the same number of times and now it only takes me about 2.5 hours to do them..... Quote Link to comment Share on other sites More sharing options...
