Vac Line Hook ups...Harness Hook ups
:question:
On a 3.1 V6 (Vin: T) on a 93 Olds Cut International......
I am swapping a 3.1 for another 3.1. The VSS sensor on the 4T60E tranny goes to where??
The Crank sensor plugs into the Ignition module HOW??? Can't find a connector.....tracing the wires tomorow....
Have various vacuum ports not connected....is there a diagram out there????
I didn't start the original engine project....bought car with eng half torn down. So there are vac lines that I don't have and don't know where to plug in....trying to find diagram....and some easy to understand wire harness hook up diagrams.....
Any info greatly appreciated!!! Thanks.,....
JackieT
the vac diagram should be on the emissions tag on the center of the radiator support. if someones pealed it off someone here is bound to be able to take a picture for you.
as far as i know the VSS goes to a few places, how it gets there i'm not sure. i know it makes a stop at the PCM, and the gauge cluster.
off the top of my head i can't think of how the crank sensor wire runs, as far as i know it is part of the engine wiring harnas so it should be there.
