hannibal64 Posted April 8, 2006 Report Posted April 8, 2006 Just trying to check everything cause i dont think its a head gasket. I think its more like a vaccum leak. Quote
95oldsVan Posted April 8, 2006 Report Posted April 8, 2006 If I remember,it should be screwed into a valve cover...pull one of the hoses off and theyre should be a plastic knob that can screw off and the pcv will be inside there...then again I might be thinking of the other 4 cylinder. Quote
hannibal64 Posted April 8, 2006 Author Report Posted April 8, 2006 dunno i took pics of what my friend says shows i have a bad head gasket thsi is what it looke like in my vac hoses running from the head. There is not a lot in there but there is some. And again no oil in coolant and no coolant in oil.. pluss i noticed when the idles rough it seems to want to lose vacum. brake lines get stiff and such. [attachment deleted by admin] Removed to free up storage space. Quote
mihela816 Posted April 8, 2006 Report Posted April 8, 2006 There is no PCV on the Quad 4. The black thing on the intake manifold is an oil/air seperator. Head gaskets are a common problem on these engines, I'd suggest you do a compression check to see if that is the problem. It could also be something like a cracked head. Quote
cutlassdude96 Posted April 9, 2006 Report Posted April 9, 2006 that doesnt to bad, if the car hasnt been driven too much in a while it could be moisture build up in the oil. hows the oil dip stick look? Quote
hannibal64 Posted April 9, 2006 Author Report Posted April 9, 2006 that doesnt to bad, if the car hasnt been driven too much in a while it could be moisture build up in the oil. hows the oil dip stick look? clean.... no gummy anything i think it is condensation that is trapped in the tube... i have a vac proble as well as a rough and i mean rough idle kinda like its missing.. exhaust sounds sputtery ... Quote
