got a 94 4 door gp and both of the i think contorl arms are rusted through in half. theyre the arms goin from the wheel up towrads the middle of the car. does anyone know how much a couple of these will cost me? thanks
The factory ones are around 50 bucks each. The GMPP tubular ones are about 50 bucks a set. Maybe someone has a part number for you...
is that part what i need cause the description doesnt include my car. i dont know what techncaly it is i jst know it goes from the wheel up towards the middle of the car, its kinda u shaped and crappily manufactured and new york winters rusted straight through it
Yeah, those are the trailing arms. The ones Gutless posted will work on your car even though they are not listed for your car.
it works after a few tries[br]Posted on: April 06, 2006, 02:06:23 AM_________________________________________________its about a foot long, its bent into sort of a u shape and goes from the rear wheel foward and up to where its mounted under to the body about a foot foward of the rear wheel. if you get down on your hands and look under the wheel housing behind the front of the rear tire you can see it busted off. theres one on each side foward of the rear wheel[br]Posted on: April 06, 2006, 02:14:31 AM_________________________________________________ok i think i got it part number 10244461
use the part number I posted. the trailing arms for newer w-bodies are the same exact size as ours. and those tubular ones will be much less prone to rust/breakage etc.
from you saying "u shaped" he definetly means trailing arms... that, and I've never heard of our control arms breaking. yet.
the rear control arms are prone to bending mine was bent and about half the cars at the j/y were broken also. the inspection guy here in MD
said it was a common problem.
