top end engine knock!!!
hey guys
i started my lumina for first time all winter today, its been in underground storage all winter long. im a little concerned though. im hearing a knock coming from the vavle train, only when you rev the engine up. Sounds similiar to the knock a rod bearing would make only its definetly coming from the front bank valvetrain.
im curious about cam bearings in the dual ohc engines. Are they a common problem?? difficult to change??? any info or ideas on what may be the problem would be greatly appreciated. thanks
  • Replies 65
  • Created
  • Last Reply
Top Posters In This Topic
  • synistershadows
    19
  • IRONDOG442
    9
  • gp90se
    5
  • GP1138
    5
hey guys
If it sat all winter, the oil is probbaly right all in the pan, everything would be unlubed. How long did you let it run for? Shouldn't be a knock, moreso a tick.
  • 1 year later...
I just started haveing this same problem with mine only i have been driving it pretty much everyday
it is over due for an oil change though but could that cause this problem?
Resolone isnt an additive its more of a detergent designed specifically to quiet valvetrain noise.
I'd let it warm up to operating temp and see if the noise goes away. One of the lifters has probably lost its prime.
Whereabouts are you in Kitchener?
and i have let it run up to temp and it still makes the noise but only when i step on the gas
Any Auto parts store its about $6.00 a a quart follow the instructions on the bottle.
I was responding to the original thread question.
drain the oil, put in 5 quarts 5w30 synthetic and a bottle of CD2 valvetrain noise stuff. Patgizz swears by royal purple, I'm a fan of syntec.
they changed formula, i read it doesnt hold up as well as it used to, been a while since I read up on it.
Remove the serpentine belt, this will isolate w/pump,power strg pump, etc. and listen for any change. Could be a something other than engine noise. Good luck
Joel
the sound is comming from the opposite side of the engine its on the drivers side front bank of the heads
least that what it sounds like
You can spend all day guessing what the noise is. You can try many many weight oils and that may not even cure the problem. I suggest you go into the engine and find out whats causing it.
