hannibal64 Posted April 2, 2006 Report Posted April 2, 2006 My 90 International started having some rough idle issues this week as well as loss of power. Checked the module to see if that was it and changed the coils.. problem was still there. Weird thing is it only does it when its warm. If i start it up cold it will run forever fine. but when i turn it off and start it, it runs rough. Pulled my plugs and they were fine also had the module checked at autozone and they said it was fine. I dont really wanna mess with it a whole lot. No oil in the coolant and no coolant in the oil. Any ideas? Forgot to say once it starts ideling rough it runs that way until it cools down completely.. takes about 4 hours. And acceleration is non existant. It boggs so bad you pretty much cant even drive it. Quote
kknobl Posted April 2, 2006 Report Posted April 2, 2006 My 90 International started having some rough idle issues this week as well as loss of power. Checked the module to see if that was it and changed the coils.. problem was still there. Weird thing is it only does it when its warm. If i start it up cold it will run forever fine. but when i turn it off and start it, it runs rough. Pulled my plugs and they were fine also had the module checked at autozone and they said it was fine. I dont really wanna mess with it a whole lot. No oil in the coolant and no coolant in the oil. Any ideas? Forgot to say once it starts ideling rough it runs that way until it cools down completely.. takes about 4 hours. And acceleration is non existant. It boggs so bad you pretty much cant even drive it. If you haven't done so already, get your ignition coils checked. This is probably a long shot but worth looking into. When I had my Quad4, the coils went bad and it would severly bog on acceleration when the engine was up to temp. Kevin Quote
hannibal64 Posted April 2, 2006 Author Report Posted April 2, 2006 chnaged the coils yesterday. no codes. it did throw a check engine light last night when i had to drive it home from a friends garage. was sitting in traffic keeping it a 2k rpms to keep it from dying. [br]Posted on: April 02, 2006, 09:38:21 AM_________________________________________________ And no codes ? Not a good sign. why not? Quote
birdman Posted April 2, 2006 Report Posted April 2, 2006 well if the engine light was on then there is at least one code. Quote
hannibal64 Posted April 5, 2006 Author Report Posted April 5, 2006 i chnged the coils.. no change - i didnt change the module becuase the guy at autozone tested it and said it was good Quote
