Fuel pump stuck....??
cutlassconvertible
Hey i had my cutlass parked for about 6 months with a full tank of gas. now it doesnt start. I have no fuel pressure. I know that when you turn the key the fuel pump is supposed to power for like 2 sec. but im not hearing it at all so im pretty sure the pump isnt working. i know i had it changed about 6months to a year before it was parked, so im pretty sure that the actual pump is good. maybe its just needs a kick start or something.
any ideas??
it could be defective ya never know? The only thing I can think of that would cause the fuel pump not to work properly is if there's a damn good amount of water or moisture that has accumulated in the line. HOWEVER, if you don't hear the pump when you turn the key, I'd say there's a 99% chance it's bad.
You need to see if you have power at the fuel pump connector which is very near the tank.
Simple test light work, should glow for 2 secs when you turn on the key and be constant during cranking. If power is there more than likely bad fuel pump, I have seen many fuel pumps with a bad spot in the pump motor where it wont go but it will go in any other spot, 1 in 6 or 1 in 10 times it will land on that spot.
Why don't you try the fuel pump test lead. :idea: Its right below the FP relay. Apply 12V to it if the pump runs you have an electrical problem. Could be as simple as a fuse. :wink:
Jud
Does any one have a photograph showing the fuel pump test point?
Yea I've got one somewhere. Been through so many host thea I don't know where it is. I'll find it.
Jud
I don't have a pic, but it is a single wire that is under the relay box by the aux post.
It's that little pigtail that's not connected to anything right? (by the aux post I mean)
Don’t think my 96 has one but it would still be nice to see a photo on earlier model.
Dont think my 96 has one but it would still be nice to see a photo on earlier model.
I snap a quick pic or two when I go down to work on my POS again either Sunday or Monday
